Home » Modeling » Papyrus » Need the source code of MARTE
Need the source code of MARTE [message #1242971] Mon, 10 February 2014 10:31 Go to next message
amina magd is currently offline amina magdFriend
I need to import the source code of MARTE to make some changes.
I use Eclipse Kepler version
I tried with this link :
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/tags/0.9.1_SR1/extraplugins/marte/org.eclipse.papyrus.marte.static.profile
But it does not work with the version of eclipse that i use (errors are generated)
What is the appropriate version of MARTE that i must use with Eclipse Kepler ?
Thanks for reply,
Amina
[Updated on: Mon, 10 February 2014 10:47]
Report message to a moderator
Re: Need the source code of MARTE [message #1243047 is a reply to message #1242971] Mon, 10 February 2014 12:51 Go to previous messageGo to next message
Resolved Smile
Re: Need the source code of MARTE [message #1249162 is a reply to message #1243047] Tue, 18 February 2014 02:19 Go to previous messageGo to next message
Vadim Peretokin is currently offline Vadim PeretokinFriend
Member
Resolved how? It would be helpful to know for others who run into the same issue.
Re: Need the source code of MARTE [message #1249473 is a reply to message #1249162] Tue, 18 February 2014 09:34 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
The source code has been moved to git:
git://git.eclipse.org/gitroot/papyrus/org.eclipse.papyrus.git
The Marte plug-ins are available under the extraplugins/marte/ folder
For Kepler, you should use the streams/0.10-maintenance branch. For Luna, you should use master.
Camille
Camille Letavernier
Re: Need the source code of MARTE [message #1387851 is a reply to message #1249473] Wed, 25 June 2014 17:31 Go to previous message
amina Mising name is currently offline amina Mising nameFriend
I tried to create a UML/MARTE profile using the source code of MARTE.
The profile is created and defined successfully, but i can not apply it on a model.
When trying to apply the created profile on a papyrus model, i get this error
the feature 'references' of 'subsets' contains an unresolved proxy 'org.eclipse.emf.ecore.impl.EObjectImpl@29b37cea{http://www.eclipse.org/papyrus/MARTE/1#//MARTE_Annexes/VSL/DataTypes/TupleType/tupleAttrib}'
(please see attached)
I am using Eclipse Kepler S2
Any help please ?
Thank you,
Best regards
  • Attachment: error.png
    (Size: 216.04KB, Downloaded 88 times)
Previous Topic:Entering Hex values in numerical attributes
Next Topic:Announcing Eclipse OCL 5.0.0 and 5.0.1 for Luna
Current Time: Mon Jan 18 11:34:43 GMT 2021
Powered by FUDForum. Page generated in 0.01829 seconds
