Home » Eclipse Projects » GEF » Keyboard shortcuts
Keyboard shortcuts [message #203290] Mon, 21 November 2005 16:22 Go to next message
Originally posted by: radicr.stop.spam.gmail.com
I would like to know how can i enable users to use CTRL+Z combination for
undo actions. I tried everything - but i cant get it to work
I am using RCP, and maybe this is the problem. I even transferred Logic
example from plugin to a RCP application, from plugin CTRL+Z works, but from
RCP it doesnt. Maybe problem is in RCP?
I have another RCP editor, and i dont know where in code i need to "turn on"
keyboard shortcut for undo. I have EditorActionBarContributor and
protected void buildActions() {
addRetargetAction(new UndoRetargetAction());
public void contributeToToolBar(IToolBarManager toolBarManager) {
toolBarManager.add(getAction(ActionFactory.UNDO.getId()));
public void contributeToMenu(IMenuManager manager) {
MenuManager editMenu = new MenuManager("&Edit",
IWorkbenchActionConstants.M_FILE);
manager.add(editMenu);
editMenu.add(getAction(ActionFactory.UNDO.getId()));
protected void declareGlobalActionKeys() {
addGlobalActionKey(ActionFactory.UNDO.getId());
in EditorPage:
protected KeyHandler getCommonKeyHandler() {
if (sharedKeyHandler == null) {
sharedKeyHandler.put(KeyStroke.getPressed('Z', SWT.CTRL, 0),
getMultipageBuildingEditor().getActionRegistry().getAction(
return sharedKeyHandler;
in MultiPageEditorPart
protected void createActions(IEditorSite site) {
addStackAction(new UndoAction(this));
ActionRegistry registry = getActionRegistry();
IActionBars bars = site.getActionBars();
String id = ActionFactory.UNDO.getId();
bars.setGlobalActionHandler(id, registry.getAction(id));
getSite().getKeyBindingService().registerAction(registry.get Action(id));
But i cant do undo with CTRL+Z. Where is the proper place to do it?
Pozdrav,
Radovan
Re: Keyboard shortcuts [message #203300 is a reply to message #203290] Mon, 21 November 2005 16:58 Go to previous messageGo to next message
I just do the same thing as in GraphicalEditor.createActions() and have no
problems.
In configureGraphicalViewer() I also have this:
KeyHandler keyHandler = new GraphicalViewerKeyHandler( viewer );
viewer.setKeyHandler( keyHandler );
But your code in getCommonKeyHandler() looks strange.
"Radovan Radic" <radicr.stop.spam@gmail.com> wrote in message
news:dlssaq$ku5$1@news.eclipse.org...
> Hello,
> from
> on"
> in EditorPage:
> Pozdrav,
> Radovan
Re: Keyboard shortcuts [message #203353 is a reply to message #203290] Mon, 21 November 2005 19:13 Go to previous messageGo to next message
Originally posted by: none.unknown.com
MultiPageEditorParts have several known issues. Search this newsgroup for
that topic.
> Hello,
from
on"
> in EditorPage:
> Pozdrav,
> Radovan
Re: Keyboard shortcuts [message #203434 is a reply to message #203300] Tue, 22 November 2005 08:39 Go to previous messageGo to next message
Thanks Felix,
I use this
private void createGraphicalViewer(Composite parent) {
viewer = new ScrollingGraphicalViewer();
viewer.createControl(parent);
viewer.getControl().setBackground(parent.getBackground());
viewer.setRootEditPart(new ScalableRootEditPart());
viewer.setKeyHandler(new GraphicalViewerKeyHandler(viewer)
.setParent(getCommonKeyHandler()));
And this is why i use getCommonKeyHandler()
I tried your code as well, but it doesnt work the same.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dlsub0$nt5$1@news.eclipse.org...
> problems.
> > Hello,
for
> > from
> > on"
> > in EditorPage:
> > Pozdrav,
> > Radovan
Re: Keyboard shortcuts [message #203564 is a reply to message #203434] Tue, 22 November 2005 20:36 Go to previous messageGo to next message
What I thought looked strange in getCommonKeyHandler() is
i.e. you are putting something into the null sharedKeyHandler.
Anyway, I don't need to add any keystrokes for the UndoAction because it is
a retarget action. My ActionBarContributor.buildActions() looks like this:
addRetargetAction( new UndoRetargetAction() );
and is specified as the contributorClass for my editor in plugin.xml.
news:dlulhe$u0k$1@news.eclipse.org...
> Thanks Felix,
> I use this
>> no
>> problems.
>> > Hello,
> for
>> > from
>> > "turn
>> > on"
>> > in EditorPage:
>> > Pozdrav,
>> > Radovan
Re: Keyboard shortcuts [message #203622 is a reply to message #203564] Wed, 23 November 2005 10:50 Go to previous messageGo to next message
I forgot that i reduced code
there are more lines in this method
sharedKeyHandler = new KeyHandler();
sharedKeyHandler.put(KeyStroke.getPressed(SWT.DEL, 127, 0),
ActionFactory.DELETE.getId()));
and with this SWT.DEL - delete key from keyboard works, but CTRL+Z with
doesnt work.
I have contributor in plugin.xml as well, but it still doesnt work.
Thank you all for your help, but i am having a lot of problems with eclipse.
Main problem is that i didnt manage to get some extensive instructions about
this matter, so i am only guessing and trying to use magic in order for my
keyboard actions work in gef.
news:dlvvgg$qm$1@news.eclipse.org...
is
> > Thanks Felix,
> > I use this
> >> no
> >> problems.
> >> > Hello,
> > for
Logic
but
> >> > from
> >> > "turn
> >> > on"
> >> > in EditorPage:
> >> > Pozdrav,
> >> > Radovan
Re: Keyboard shortcuts [message #203630 is a reply to message #203622] Wed, 23 November 2005 11:11 Go to previous messageGo to next message
news:dm1hj5$ugs$1@news.eclipse.org...
> doesnt work.
eclipse.
about
In fact, what i want to say is that i dont know where in code i should put
proper lines that would enable my actions to work. Problem could be because
i am using MultiPageEditorActionBarContributor and i dont know where could i
do addRetargetAction(new UndoRetargetAction());
Maybe problem is in rcp, i have no idea.
> is
this:
> > > Thanks Felix,
> > > I use this
have
> > >> no
> > >> problems.
> > >> > Hello,
combination
> > > for
> Logic
> but
> > >> > from
> > >> > "turn
> > >> > on"
> > >> > in EditorPage:
> > >> > Pozdrav,
> > >> > Radovan
Re: Keyboard shortcuts [message #204840 is a reply to message #203564] Thu, 08 December 2005 08:55 Go to previous message
Try this:
KeyStroke.getPressed((char) ('z' - 'a' + 1), 'z', SWT.CTRL),
getActionRegistry().getAction(ActionFactory.UNDO.getId()));
This works for my GEF-Editor.
Stefan
Previous Topic:Is there an example of using a DirectEditPolicy with an AbstractTreeEditPart?
Next Topic:how to refresh editpart on editorpage
Current Time: Wed Feb 19 06:47:33 GMT 2025
Powered by FUDForum. Page generated in 0.03929 seconds
