Home » Eclipse Projects » GEF » Convert accelerator to KeyStroke?
Convert accelerator to KeyStroke? [message #203285] Mon, 21 November 2005 16:00 Go to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
I am using several retarget actions. I am setting the commandId/definitionId
on them, and their accelerators show properly in the context menu. But I
still need to set the
accelerator in the KeyHandler in order for the keys to actually trigger an
action. Is this supposed
to work automatically or should I get the accelerator from the action and
put the appropriate KeyStroke with the action into the KeyHandler? In the
latter case, is there a simple way to convert the accelerator into a
KeyStroke?
Re: Convert accelerator to KeyStroke? [message #203315 is a reply to message #203285] Mon, 21 November 2005 17:06 Go to previous messageGo to next message
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dlsqvh$iut$1@news.eclipse.org...
>commandId/definitionId on them, and their accelerators show properly in the
>context menu. But I still need to set the
> KeyStroke?
Let me clarify this a little. For several actions, the accelerators work
fine, and I don't have to tell the KeyHandler about them (undo, redo,
delete). But for selectAll and some others I have to put into the KeyHandler
with a KeyStroke, which means that the accelerator is hardcoded. So I am not
sure if I am missing something with the action or if I need convert the
accelerator into a KeyStroke.
Re: Convert accelerator to KeyStroke? [message #203337 is a reply to message #203315] Mon, 21 November 2005 18:59 Go to previous messageGo to next message
Originally posted by: none.unknown.com
SelectAll works fine in the logic example. Are you declaring it as a global
action key in the ActionBarContributor?
news:dlsurc$ooa$1@news.eclipse.org...
the
an
and
the
> > KeyStroke?
KeyHandler
not
Re: Convert accelerator to KeyStroke? [message #203417 is a reply to message #203337] Mon, 21 November 2005 23:45 Go to previous message
Thanks, with that I got selectAll to work.
Then I did the same thing for 'Open' and 'Open Type Hierarchy', but F3 and
F4 don't work. I created RetargetActions with ids JdtActionConstants.OPEN
and JdtActionConstants.OPEN_TYPE_HIERARCHY, and I set the definitionIds to
IJavaEditorActionDefinitionIds.OPEN_EDITOR and
IJavaEditorActionDefinitionIds.OPEN_TYPE_HIERARCHY on my actions. So
basically I did the same thing as with selectAll, but it doesn't work.
"Pratik Shah" <none@unknown.com> wrote in message
news:dlt5dr$36l$1@news.eclipse.org...
> global
> the
> an
> and
> the
>> > KeyStroke?
> KeyHandler
> not
Previous Topic:How can I do an editable Text inside Shape?
Next Topic:selection of multiple nodes
Current Time: Sat Dec 14 01:13:48 GMT 2024
Powered by FUDForum. Page generated in 0.06455 seconds
