Managed Build: Specifying linked tool options [message #203271] |
Tue, 23 October 2007 12:32 |
Tracy Miranda Messages: 16 Registered: July 2009 |
Junior Member |
I have a question which is related to bugzilla bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44745. The bug report is
about linking options such that they can be applied to more than one tool,
e.g. setting a profiling option such that it passes -pg to both the
compiler and linker command lines.
It says this can be achieved by using "option enablement/adjustment
expressions and option value handler mechanisms".
This is a request for a simple example that would show how I could use the
same option across multiple tools, say given a compiler tool and a linker
tool. Where would you specify the option such that it modifies both the
command line tools ?
Can this be done purely in xml ?
Tracy
FUDForum. Page generated in 0.02705 seconds
