Re: Cross references in DSLs of xtext [message #1240895 is a reply to message #1240862] |
Fri, 07 February 2014 07:45 |
Hi Christian,
I just want this because I don't want to include namespace in referenced objects always.
i.e. instead of SomeName.a1, SomeName.a2, I will add an import statement which says
import SomeName.*;
and then use a1, a2 and so on directly. But when this SomeName dsl is present in the other folder as explained above, I am not able to refer it, it says it couldn't resolve it.
Arshad
Arshad
Re: Cross references in DSLs of xtext [message #1240898 is a reply to message #1240895] |
Fri, 07 February 2014 07:50 |
this will work out of the box if
. you reference the stuff as described in my blog
- have a construct with importedNamespace
so what do you mean with other folder? as i said: if the other folder is in the same project or a referenced project it is fine.
and it will work out of the box.
if not you have to share more detail...
Twitter : @chrdietrich
FUDForum. Page generated in 0.03774 seconds
