javadoc Problem with code compiled by Xtend 2.5.1 [message #1240337] |
Thu, 06 February 2014 08:54 |
Axel Guckelsberger Messages: 354 Registered: July 2009 |
Hi all,
after having updated Xtext and Xtend from 2.5.0 to 2.5.1 some Jenkins builds fail because javadoc thinks the generated Java code was illegal.
[ant] Javadoc started
[ant] /var/lib/jenkins/.../xtend-gen/.../CollectionUtils.java:27: illegal start of expression
[ant] _xblockexpression = (IterableExtensions.<Object>filter(unfiltered, new Function1<Object,Boolean>() {
[ant] ^
[ant] /var/lib/jenkins/.../xtend-gen/.../ControllerExtensions.java:217: illegal start of expression
[ant] _xblockexpression = (Iterables.<Controller>concat(_filter, _filter_1));
[ant] ^
[ant] /var/lib/jenkins/.../xtend-gen/.../ModelJoinExtensions.java:689: illegal start of expression
[ant] _xblockexpression = (IterableExtensions.<OneToManyRelationship>findFirst(_filter, _function));
[ant] ^
[ant] /var/lib/jenkins/.../xtend-gen/.../ModelJoinExtensions.java:727: illegal start of expression
[ant] _xblockexpression = (IterableExtensions.<DerivedField>findFirst(_filter, _function));
[ant] ^
Interestingly the build itself works without problems.
Is this a javadoc bug then? Has anybody seen something like this?
I tried to increase the Java source level in the javadoc ant task (changed source="1.6" to source="1.7"), but this did not change anything.
Thanks in advance,
Axel
[Updated on: Thu, 06 February 2014 08:55] Report message to a moderator
FUDForum. Page generated in 0.04006 seconds
