e4 FX application test case are not running [message #1240303] |
Thu, 06 February 2014 06:56 |
I am Working with e(fx)clipse 0.9.0 and java 8 build 105, every thing was running fine till feb 3 2014,but from feb 4 when I am running same e4 FX application getting below error from eclipse
ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 12:03:19.425
!MESSAGE [SCR] Cannot activate instance <missing argument> of component Component[
name = com.ventana.dp.analysis.internal
activate = start
deactivate = stop
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = com.ventana.dp.analysis.tools.osgiservices.AnalysisOSGIService
state = Unsatisfied
properties =
serviceFactory = false
serviceInterface = [com.ventana.dp.common.app.model.domain.ToolBarItemModel]
references = null
located in bundle = com.ventana.dp.analysis.tools_1.0.0.qualifier [140]
]! The specified activate method was not found!
and also getting this error when build the code from maven
[INFO] Command line:
cmd.exe /X /C ""C:\Program Files\Java\jdk1.8.0\jre\bin\java.exe" -Dosgi.noShutdown=false -Dosgi.os=win32 -Dosgi.ws=win32 -Dosgi.arch=x86_64 -Xms40m -Xmx512m -Defxclipse.osgi.hook.debug=true -Dosgi.framework.extensions=org.eclipse.fx.osgi -Dtest.jemmy.product=com.ventana.dp.analysis.app.product -jar C:\Users\invbajpai\.m2\repository\p2\osgi\bundle\org.eclipse.equinox.launcher\1.3.0.v20130327-1440\org.eclipse.equinox.launcher-1.3.0.v20130327-1440.jar -
!SESSION 2014-02-06 11:55:25.050 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0-ea
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
!ENTRY org.eclipse.osgi 4 0 2014-02-06 11:55:25.210
!MESSAGE error loading hook: org.eclipse.fx.osgi.fxloader.FXClassLoadingConfigurator
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/osgi/baseadaptor/HookConfigurator
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:752)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:442)
at java.net.URLClassLoader.access$100(URLClassLoader.java:64)
at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:258)
at org.eclipse.osgi.internal.hookregistry.HookRegistry.loadConfigurators(HookRegistry.java:185)
at org.eclipse.osgi.internal.hookregistry.HookRegistry.initialize(HookRegistry.java:106)
at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:73)
at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:287)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:222)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:491)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.ClassNotFoundException: org.eclipse.osgi.baseadaptor.HookConfigurator
at java.net.URLClassLoader$1.run(URLClassLoader.java:359)
... 27 more
!ENTRY org.eclipse.osgi 4 0 2014-02-06 11:55:25.213
!MESSAGE error loading hook: org.eclipse.fx.osgi.patch.PFConfigurator
!STACK 0
... 27 more
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:25.891
!MESSAGE [SCR] Exception while activating instance <missing argument> of component com.ventana.dp.analysis.internal
!STACK 0
java.lang.NoClassDefFoundError: javafx/scene/Scene
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2594)
at java.lang.Class.getDeclaredMethods(Class.java:1886)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:213)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at java.lang.Thread.run(Thread.java:724)
Caused by: java.lang.ClassNotFoundException: javafx.scene.Scene cannot be found by osgi.identity; osgi.identity="com.ventana.dp.analysis.tools"; type="osgi.bundle"; version:Version="1.0.0.201402060624"; singleton:="true"
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:365)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:331)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:323)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
... 15 more
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:25.893
!STACK 0
... 15 more
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:25.896
!MESSAGE [SCR] Exception while activating instance <missing argument> of component com.ventana.dp.analysis.imgtools.sdkanalysis
!STACK 0
... 15 more
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:25.914
!STACK 0
... 15 more
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.050
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
references = null
located in bundle = com.ventana.dp.analysis.tools_1.0.0.201402060624 [80]
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.052
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.055
name = com.ventana.dp.analysis.imgtools.sdkanalysis
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
implementation = com.ventana.dp.analysis.tools.osgiservices.SDKAnalysisOSGIService
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.057
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.062
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.064
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
references = null
!ENTRY org.eclipse.equinox.ds 4 0 2014-02-06 11:55:26.067
activate = start
deactivate = stop
modified =
factory = null
autoenable = true
immediate = true
state = Unsatisfied
properties =
Can any body help me
FUDForum. Page generated in 0.03004 seconds
