No outline view in default UML editor? [message #1240012] |
Wed, 05 February 2014 14:17 |
Hi!
I'm just wondering.. is there a reason why the Outline view is disabled
in the default UML model editor? Found in UMLEditor:
* Returns whether the outline view should be presented to the user.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected boolean showOutlineView() {
return false;
Cheers
Patrick
Re: No outline view in default UML editor? [message #1240060 is a reply to message #1240034] |
Wed, 05 February 2014 16:07 |
Hi Ed,
Thanks for the quick reply. That would indeed be helpful :-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=427481
Cheers
Patrick
Am 05.02.2014 16:15, schrieb Ed Willink:
> Hi
> Probably for the same reason as the Sample Ecore Editor; it would be
> redundant.
> However if you use any large unfriendly model such as UML.uml, you will
> find that the lack of alphabetic ordering makes finding classes a real
> pain. The outline can have an alphabetic ordering option, so it is not
> redundant after all.
> How about a Bugzilla?
> Regards
> Ed Willink
> On 05/02/2014 14:17, Patrick Könemann wrote:
>> Hi!
>> * @generated
>> return false;
>> Cheers
>> Patrick
FUDForum. Page generated in 0.02363 seconds
