Adding another file into the generated src-gen folder with Xtext-xtend compiler [message #1239890] |
Wed, 05 February 2014 09:18 |
mcse mcse Messages: 53 Registered: August 2012 |
Member |
I create a runnable jar file from my xtext-xtend project so that my compiler can be used as a standalone jar.
When the jar file is run, the output is a folder (src-gen) including the generated code files.
However, I also want to include another separate file in the src-gen. I have added this file(XcD_PACKAGE.h) winthin the same package as the Main.java of my project.
Then, I use the following code snippet in the Main.java so as to create a copy of the XcD.PACKAGE.h file in the generated src-gen folder.
However, this does not work unfortunately.
Can anyone please help me on this ?
Thanks.
protected void runGenerator(String string) {
// load the resource
ResourceSet set = resourceSetProvider.get();
Resource resource = set.getResource(URI.createURI(string), true);
// validate the resource
List<Issue> list = validator.validate(resource, CheckMode.ALL, CancelIndicator.NullImpl);
if (!list.isEmpty()) {
for (Issue issue : list) {
System.err.println(issue);
return;
// configure and start the generator
fileAccess.setOutputPath("src-gen/");
generator.doGenerate(resource, fileAccess);
ClassLoader cl = this.getClass().getClassLoader();
java.io.InputStream is = cl.getResourceAsStream("org.xtext.example.mydsl.generator/XcD_PACKAGE.h");
fileAccess.generateFile("XcD_PACKAGE.h",is);
System.out.println("Code generation finished.");
Re: Adding another file into the generated src-gen folder with Xtext-xtend compiler [message #1239945 is a reply to message #1239934] |
Wed, 05 February 2014 11:09 |
Member |
I used the following function to read from the file.
def addIncludeFile() '''
«val File incfile = new File("..\\!includefiles\\" + "XcD_PACKAGE.h")»
«IF incfile.exists()»
«FOR String line : (new FileReader(incfile)).readLines»
«line»
«ENDFOR»
«ENDIF»
Then, I used the following command to create the new file during the code generation process. The file is created succesfully, but has no content. So, the function above does not work. Can you please let me know what is wrong with the above function ?
fsa.generateFile("XcD_PACKAGE.h",addIncludeFile());
[Updated on: Wed, 05 February 2014 14:44] Report message to a moderator
Re: Adding another file into the generated src-gen folder with Xtext-xtend compiler [message #1240156 is a reply to message #1239890] |
Wed, 05 February 2014 20:45 |
Member |
Thanks a lot again.
I have placed the file, which needs to be copied inside the generated src-gen folder,
into the same package as the Main.java and my xtend file.
So, the file do exist in the same package.
My xtend file content is like the following:
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
var String exceptions_mtype = "";
root = resource.contents.head as compilationUnits;
fsa.generateFile("XcD_PACKAGE.h",Resources.toString(Main.getResource("/XcD_PACKAGE.h"), Charsets.UTF_8));
The Main.java that executes the xtend file has the following content.
public class Main {
if (args.length==0) {
System.err.println("Aborting: no path to EMF resource provided!");
return;
Injector injector = new XcdStandaloneSetupGenerated().createInjectorAndDoEMFRegistration();
Main main = injector.getInstance(Main.class);
main.runGenerator(args[0]);
@Inject
private Provider<ResourceSet> resourceSetProvider;
@Inject
private IResourceValidator validator;
@Inject
private IGenerator generator;
@Inject
private JavaIoFileSystemAccess fileAccess;
return;
So, the compiler (that I deploy as runnable jar) generates a folder with some files of generated codes. However, I also want to create a copy of a file in the folder. Indeed, it is this file that is located in the same package as Main.java.
FUDForum. Page generated in 0.05533 seconds
