Home » Modeling » Papyrus » UMLMetaModel extension
UMLMetaModel extension [message #1239601] Tue, 04 February 2014 15:16 Go to next message
Johan Hardy is currently offline Johan HardyFriend
Member
Dear all,
I'm interested in a special extension of papyrus: UMLMetamodel
Did anybody try to implement anything with extension org.eclipse.papyrus.uml.extensionpoints.UMLMetamodel ?
What is your feedback ?
I would like to make a test. Please, any documentation on this extension is welcome.
Best regards;
Johan
Re: UMLMetaModel extension [message #1239688 is a reply to message #1239601] Tue, 04 February 2014 20:06 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Johan,
The org.eclipse.papyrus.uml.extensionpoints plug-in, itself, registers
a couple of metamodels provided by the Eclipse UML2 project on this
extension point:
UML.metamodel.uml
Ecore.metamodel.uml
Consequently, these models are available for the user to choose in the
metamodel-selection dialogs provided by that plug-in. However, neither
of these dialogs appears to be used currently by Papyrus (as far as I
can tell).
Christian
On 2014-02-04 15:16:25 +0000, Johan Hardy said:
> Dear all,
> Best regards;
> Johan
Re: UMLMetaModel extension [message #1239864 is a reply to message #1239688] Wed, 05 February 2014 08:18 Go to previous messageGo to next message
Member
Dear Christian,
Many thanks for your answer. I guess it is part of future uses or developments of UML2.
Regards;
Johan
Re: UMLMetaModel extension [message #1240004 is a reply to message #1239864] Wed, 05 February 2014 14:04 Go to previous messageGo to next message
Hi, Johan,
Not of UML2, but of Papyrus. This extension point is implemented by
Papyrus. And the dialogs that use it are available (at least in the
Kepler release) for extenders to use; I don't know whether they will be
public API in the Luna release ...
Christian
On 2014-02-05 08:18:58 +0000, Johan Hardy said:
> Dear Christian,
> Regards;
> Johan
Re: UMLMetaModel extension [message #1240017 is a reply to message #1240004] Wed, 05 February 2014 14:34 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
I'm not aware of any plan for making them available in the (near) future. This is actually an old extension point which is currently not used. Unless there are specific needs and use cases for this, it will probably remain as-is.
Camille
Camille Letavernier
Re: UMLMetaModel extension [message #1240920 is a reply to message #1240017] Fri, 07 February 2014 08:27 Go to previous message
Member
ok thank you for your answers, topic is closed Smile
Regards;
Johan
Previous Topic:Automatic instanciation of a pattern using EMF concepts
Next Topic:API Definition
Current Time: Sat Jan 23 08:57:53 GMT 2021
Powered by FUDForum. Page generated in 0.02020 seconds
