Home » Eclipse Projects » GEF » FigureUtilities.getTextExtents
FigureUtilities.getTextExtents [message #202588] Fri, 11 November 2005 10:37 Go to next message
Originally posted by: james.willans.xactium.com
We are using FigureUtilities.getTextExtents and the results we are getting
suggests that the result is the same regardless of whether the font's
style is set to italic or not. Is it really the case that getTextExtents
ignores this?
James
Re: FigureUtilities.getTextExtents [message #202616 is a reply to message #202588] Fri, 11 November 2005 14:46 Go to previous messageGo to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
Could it be that this result is actually correct?
"James Willans" <james.willans@xactium.com> wrote in message
news:1a4912467ca8184eb4a99cf15af77896$1@www.eclipse.org...
> ignores this?
> James
Re: FigureUtilities.getTextExtents [message #202640 is a reply to message #202616] Fri, 11 November 2005 15:14 Go to previous messageGo to next message
You may be right, it could be GCs rendering of the italicised text that is
wrongly truncating the width. Is this something you've experienced?
James
>> Hi,
>> ignores this?
>> James
Re: FigureUtilities.getTextExtents [message #202654 is a reply to message #202640] Fri, 11 November 2005 16:31 Go to previous messageGo to next message
No, I am just trying to clarify the situation. I have looked at italicized
Arial fonts, and in most cases I would not expect the italicized version of
a string to be longer than the normal one, depending on the last character.
If you are actually seeing letters being cut off, then I don't know.
news:5572cb6219ce264ff2b50ea9aff32ebe$1@www.eclipse.org...
> James
>>> Hi,
>>> getting suggests that the result is the same regardless of whether the
>>> font's style is set to italic or not. Is it really the case that
>>> getTextExtents ignores this?
>>> James
Re: FigureUtilities.getTextExtents [message #202668 is a reply to message #202588] Fri, 11 November 2005 16:35 Go to previous messageGo to next message
You are seeing the result returned from win32. I don't think italics affect
the width result, even though they clearly require more pixels at the time
of painting, in some cases.
> ignores this?
> James
Re: FigureUtilities.getTextExtents [message #202704 is a reply to message #202668] Fri, 11 November 2005 17:24 Go to previous message
For example when "Named" is rendered we are seeing "Nameo". I have tried
adding a bit to the values calculated by FigureUtilities.getTextExtents
but this doesn't remedy the issue. I think the following GC bug reported
by Pratik might be the root of this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=93447
James
Previous Topic:How can I employ Print Action?
Next Topic:Draw2D does not work correct when I change the Label font size
Current Time: Sat Dec 07 02:43:47 GMT 2024
Powered by FUDForum. Page generated in 0.03308 seconds
