Home » Eclipse Projects » GEF » Clipping problem
Clipping problem [message #202444] |
Wed, 09 November 2005 19:09  |
I have a strange problem when moving label children of a connection:
When to connection has just 2 labels, everything works fine, i.e. I can move
around the labels where I want. But when the connection has 4 labels and I
move one of them, it does not get redrawn at the target location. I debugged
my code and everything looks fine, but in Figure.paintChildren() the label
child does not intersect Graphics.getClip() and therefore is not painted.
The clipping region is much smaller when there are 4 children than when
there are 2. What can I do about this?
Re: Clipping problem [message #202632 is a reply to message #202444] |
Fri, 11 November 2005 15:10   |
Since nobody seems to know anything, let me rephrase my question:
How it the clipping Rectangle in Graphics determined?
What can I do to influence it?
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dkthhh$7ir$1@news.eclipse.org...
> move around the labels where I want. But when the connection has 4 labels
> and I move one of them, it does not get redrawn at the target location. I
> debugged my code and everything looks fine, but in Figure.paintChildren()
> the label child does not intersect Graphics.getClip() and therefore is not
> painted. The clipping region is much smaller when there are 4 children
> than when there are 2. What can I do about this?
Re: Clipping problem [message #202690 is a reply to message #202444] |
Fri, 11 November 2005 16:37   |
The clip region should be exactly the bounds of hte figure being painted.
The parent sets it.
Re: Clipping problem [message #202742 is a reply to message #202690] |
Fri, 11 November 2005 22:12   |
Thanks, that enabled me to find the problem. The basic issue is the clipping
in Figure.paintChildren() in conjunction with the bounds of a
PolylineConnection, which seems to be determined by its points. For a
PolylineConnection whose child figures are anywhere on the diagram, the
chances are good that their bounds don't intersect with the
PolylineConnection one's, and then they don't get drawn.
I was able to get the behavior I want by creating my own ConnectionLayer
which removes all clipping from paintChildren(). I also tried to overwrite
PolylineConnection.getBounds() to union all the children in the bounds, but
that didn't produce the desired effect.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dl2hcv$29n$1@news.eclipse.org...
> The parent sets it.
>> not painted. The clipping region is much smaller when there are 4
>> children than when there are 2. What can I do about this?
Re: Clipping problem [message #202819 is a reply to message #202742] |
Sun, 13 November 2005 03:41   |
news:dl350b$ti$1@news.eclipse.org...
> clipping in Figure.paintChildren() in conjunction with the bounds of a
Which is why we go any fix the bounds in the specialized implementation of
layout() in PolylineConnection. Please see the EDiagram example for labeled
connections.
Re: Clipping problem [message #202877 is a reply to message #202819] |
Mon, 14 November 2005 16:53   |
news:dl6clf$jp5$1@news.eclipse.org...
> labeled connections.
Have you made those labels moveable to anywhere in the diagram?
That's when I started running into problems. When I just used a
ConnectionEndPointLocator, there was always some overlap between the
PolylineConnection's bounds and the labels, so they did get drawn. The
reason I mention this is that I see now that my 3.1.1 version of
PolylineConnection has layout() and getBounds() in place, but that didn't
help me.
Then I overrode paintChildren() in my subclass of PolylineConnection and the
label was drawn correctly after I moved it, but when it got deselected it
disappeared again.
Only my patch to the ConnectionLayer resolved the issue.
Re: Clipping problem [message #202885 is a reply to message #202877] |
Mon, 14 November 2005 21:56   |
They are not movable per se but in some cases their bounds are entirely
outside the bounds of the connection. So if the connection's bounds were not
larger they would be clipped.
Is your diagram using freeform everywhere?
If you are hacking the clipping when you paint, then at some point you will
experience painting bugs. When your figure erases itself, it only damages
the area it used to occupy. If you were painting outside of that area, that
painting will linger until something else causes it to be repainted.
news:dlafem$ph0$1@news.eclipse.org...
>> of layout() in PolylineConnection. Please see the EDiagram example for
> help me.
> the label was drawn correctly after I moved it, but when it got deselected
> it disappeared again.
Re: Clipping problem [message #202919 is a reply to message #202885] |
Mon, 14 November 2005 23:21   |
Actually I think my problem is that Figure.bounds is not set to null because
PolylineConnection.layout() is not called by
DeferredUpdateManager.fireValidating().
What could be the cause of this?
news:dlb15m$je8$1@news.eclipse.org...
> not larger they would be clipped.
> will experience painting bugs. When your figure erases itself, it only
> damages the area it used to occupy. If you were painting outside of that
> area, that painting will linger until something else causes it to be
> repainted.
>> help me.
>> deselected it disappeared again.
Re: Clipping problem [message #203008 is a reply to message #202919] |
Wed, 16 November 2005 04:08   |
A call to Figure.revalidate() in refreshVisuals() of the ConnectionEditPart
solved the problem without any hack in the clipping.
news:dlb65m$qb6$1@news.eclipse.org...
> because PolylineConnection.layout() is not called by
>> repainted.
>>>>> the chances are good that their bounds don't intersect with the
>>> didn't help me.
Re: Clipping problem [message #203086 is a reply to message #202919] |
Thu, 17 November 2005 15:52   |
A layout will only happen if a revalidate() happened previously. Did you
make a change to the connection that you thought would trigger a
revalidate()? I'd have to see the code to help you more.
Re: Clipping problem [message #203117 is a reply to message #203086] |
Thu, 17 November 2005 17:59   |
As you can see in my post from 11/15/2005, I am now calling a
Figure.revalidate() in my EditPart, and this solved my problem. There is
just so much to learn about GEF...
news:dli8vl$5k3$1@news.eclipse.org...
Re: Clipping problem [message #203134 is a reply to message #203117] |
Thu, 17 November 2005 20:47   |
news:dligeb$i50$1@news.eclipse.org...
I saw that. but why are you calling it manually? What is it you are doing
that requires the bounds to be recalculated, yet it isn't happening for
free? For example, setLineWidth should update the bounds.
setRoutingConstraint calls revalidate. adding or removing a child calls
revalidate too. It makes me think you might be doing something strange like
manipulating the PointList directly or something.
Re: Clipping problem [message #203141 is a reply to message #203134] |
Fri, 18 November 2005 15:04   |
news:dliq8a$1bu$1@news.eclipse.org...
> like manipulating the PointList directly or something.
I am moving a child label of the connection. This does not trigger a
revalidate() of the connection, so the its bounds are not recalculated and
the label gets clipped. I don't see this problem with 2 labels, because then
I have a decoration at one end. The decoration is always reset in
refreshVisuals(), which does cause a revalidate().
Re: Clipping problem [message #204414 is a reply to message #203141] |
Fri, 02 December 2005 19:10   |
So you would see the exact same problem with plain old figures. If you moved
a child, the parent would not automatically expand to encompass the child.
This is why the validation mechanism is the preferred way for position
anything.
> then I have a decoration at one end. The decoration is always reset in
Re: Clipping problem [message #206065 is a reply to message #204414] |
Fri, 23 December 2005 23:12  |
Saw your reply only just now. What do you mean by the validation mechanism?
news:dmq670$ckq$1@news.eclipse.org...
> moved a child, the parent would not automatically expand to encompass the
> child. This is why the validation mechanism is the preferred way for
> position anything.
>> and the label gets clipped. I don't see this problem with 2 labels,
>> because then I have a decoration at one end. The decoration is always
>> reset in refreshVisuals(), which does cause a revalidate().
Current Time: Wed Feb 12 14:46:37 GMT 2025
Powered by FUDForum. Page generated in 0.05881 seconds
