Home » Archived » Buckminster » Buckminster reporting skipped tests as failures?
Buckminster reporting skipped tests as failures? [message #1238409] Sat, 01 February 2014 08:27
Volker Stolz is currently offline Volker StolzFriend
Member
I have a few unit tests using JUnit's Assume.assumeTrue() that skip the tests e.g. on machines where necessary software is not available. Within Eclipse, these tests are correctly reported as skipped (not failed). The log-file produced by innovating Bucky's (4.3) "emma" (I'm also recording coverage with Jacoco) though on Jenkins shows:
    <failure>org.junit.internal.AssumptionViolatedException: MY_CUSTOM_MESSAGE_HERE
	at org.junit.Assume.assumeTrue(Assume.java:59)
	at deadlock.DeadlockCheckerTests.onError(DeadlockCheckerTests.java:21)
	at abs.frontend.typesystem.ExamplesTypeChecking.parse(ExamplesTypeChecking.java:37)
	at deadlock.DeadlockCheckerTests.parse(DeadlockCheckerTests.java:26)
	at abs.frontend.parser.ParseSamplesTest.test(ParseSamplesTest.java:54)
	at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
and thus Jenkins reports them as failed. Is this expected? The mailing lists seems to indicate that at least via ANT or Maven skipped tests are accounted correctly in Jenkins.
Previous Topic:Cross-platform builds with buckminster 4.3
Next Topic:Bundle .... cannot be resolved. Why?
Current Time: Mon Jan 27 14:13:06 GMT 2020
Powered by FUDForum. Page generated in 0.02335 seconds
