Re: Teneo + GMF Problems [message #1238242 is a reply to message #1237792] |
Fri, 31 January 2014 19:34 |
Hi Angel,
I am afraid that I can't be of much help on this one. Teneo/GMF combination is not being used a lot (you are the first
in many years who posts on this on the forum), I guess the exception you note is more from the EMF layer than from Teneo.
But that's all I can say about it...
gr. Martin
On 01/30/2014 05:49 PM, Angel Lopez wrote:
> Dear all.
> I'm involved in a project which has a key requirement of storage the models in a database. We have chosen Teneo as the
> Tecnology to use to achieve this goal.
> I have read the https://wiki.eclipse.org/Teneo/Hibernate/Editor_Tutorial to adapt my EMF/EEF models editors in order to
> persist the models in database with success.
> Now I need to adapt my GMF Editors. To learn how to do so I have followed the
> https://wiki.eclipse.org/Teneo/Hibernate/GMF and downloaded the associated MindMap example
> http://git.eclipse.org/c/teneo/org.eclipse.emf.teneo.git/tree/examples/gmf?h=TENEO1_0_4.
> The example doesn't work correctly, the dbtables are generated but doesn't save the model neither the diagram in db,
> remaining stored as files.
> I'm using newer version of Teneo 2.0.1 and GMF SDK 3.0.2 but I don't think this is the problem because the EMF editors
> works, but i'm not sure. Anyway, i have applied this steps to my model editor with the same result.
> Later I have changed my strategy. Now I'm trying to store only the model managed by the GMF editor in database
> mantaining the diagram as file. To do this, I have changed the EMF editor as the Teneo EMF tutorial says and changed the
> MyModelDiagramEditor code as says the Teneo GMF Tutorial.
> Now I'm having the following error during the save Operation or when I change the name of a GMF Node representing one
> model concept:
> java.lang.IllegalStateException: Cannot modify resource set without a write transaction
> I will appreciate any help about how to solve the problem with the mindmap example or to solve the error with my strategy.
> Many thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Teneo + GMF Problems [message #1239208 is a reply to message #1239179] |
Mon, 03 February 2014 16:45 |
Hi Angel,
I have no idea myself, it could be caused by newer versions of GMF/Teneo, as you say, the combination of Teneo/GMF has
not appeared for several years on this forum. If it gets very popular then I am sure to spend some more time there.
Until that moment, it is somewhat in the open.
So I am not sure if there is anyone who can give you a working example, without spending several hours on that first...
gr. Martin
On 02/03/2014 04:10 PM, Angel Lopez wrote:
> Many thanks for your response Martin.
> Do you know why the mindmap example doesn't save the model and diagram to database?. Can be caused for using newer
> versions of Teneo, EMF, GMF?
> A working example will be a great help for me.
> Best Regards.
The Netherlands
FUDForum. Page generated in 0.04048 seconds
