Home » Modeling » EMF » [CDO/Dawn] Deadlocking w/ Display, Dawn's handleViewInvalidationEvent, & CDO's InvalidationRunna
[CDO/Dawn] Deadlocking w/ Display, Dawn's handleViewInvalidationEvent, & CDO's InvalidationRunna [message #1237458] Wed, 29 January 2014 19:34 Go to next message
Josh M is currently offline Josh MFriend
I am hoping that someone might be able to help me with a problem with deadlocks that we are having. This problem seems to present itself when the following state occurs:
[1] The CDOView/Transaction is locked by some process.
[2] A process executing on the display thread attempts to access the model, and subsequently must wait for the CDOView/Transaction lock. This process may be native to the display thread, or may be a Runnable queued by Display.asyncExec or Display.syncExec. This process can originate from anywhere in the application.
[3] Within the process of #1, a separate and synchronized process is set to run against the display thread.
Specific to CDO/Dawn, we are seeing this problem primarily within CDO's InvalidationRunnable and Dawn's DawnAtrtGMFHandler.handleViewInvalidationEvent. Within the handleViewInvalidationEvent, refreshes to the diagram result in calls to the following areas (there may be more), each of which demonstrate the conditions of #3 above:
a. org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(Runnable) [called within DawnDiagramUpdater.refreshEditPart]
b. org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditPart.installBendpointEditPolicy() [called within ConnectionEditPart.refreshVisuals]
As this deadlock issue present's itself randomly (most likely due to timing), it is very hard to generate a test that is sufficiently reproducible, although I hope the logic described above suffices to outline the fundamental problem. We are seeing this issue more frequently in our application, compared to the ACore example, most likely due to the much higher occurrences of #2 above. I was however, able to get a thread trace of this deadlock occurring within the ACore example (pasted below).
Can you recommend a way forward to deal with this issue permanently? This problem is approaching critical for our use of CDO and Dawn. Thanks!
Example Acore Deadlock Thread trace:
org.eclipse.equinox.launcher.Main at localhost:57194
      Thread [main] (Suspended)
         owns: RunnableLock  (id=138)
         waiting for: CDOTransactionImpl  (id=139)
            owned by: Thread [CDOViewInvalidationRunner-Transaction 6] (Suspended)
         CDOStoreImpl.remove(InternalEObject, EStructuralFeature, int) line: 479
         CDOLegacyAdapter.notifyRemove(EStructuralFeature, int) line: 250
         CDOLegacyAdapter.notifyChanged(Notification) line: 125
         NodeImpl(BasicNotifierImpl).eNotify(Notification) line: 374
         ENotificationImpl(NotificationImpl).dispatch() line: 1027
         ConnectorImpl(EdgeImpl).setTarget(View) line: 215
         DawnGMFHandler$2$1.doExecute() line: 181
         DawnGMFHandler$2$1(RecordingCommand).execute() line: 135
         EMFCommandOperation.doExecute(IProgressMonitor, IAdaptable) line: 119
         EMFCommandOperation(AbstractEMFOperation).execute(IProgressMonitor, IAdaptable) line: 150
         DefaultOperationHistory.execute(IUndoableOperation, IProgressMonitor, IAdaptable) line: 513
         WorkspaceCommandStackImpl.doExecute(Command, Map<?,?>) line: 208
         WorkspaceCommandStackImpl(AbstractTransactionalCommandStack).execute(Command, Map<?,?>) line: 165
         WorkspaceCommandStackImpl(AbstractTransactionalCommandStack).execute(Command) line: 219
         DawnGMFHandler$2.run() line: 174
         RunnableLock.run() line: 35
         UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 135
         Display.runAsyncMessages(boolean) line: 4144
         Display.readAndDispatch() line: 3761
         Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2701
         Workbench.runUI() line: 2665
         Workbench.access$4(Workbench) line: 2499
         Workbench$7.run() line: 679
         Realm.runWithDefault(Realm, Runnable) line: 332
         Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 668
         PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
         IDEApplication.start(IApplicationContext) line: 124
         EclipseAppHandle.run(Object) line: 196
         EclipseAppLauncher.runApplication(Object) line: 110
         EclipseAppLauncher.start(Object) line: 79
         EclipseStarter.run(Object) line: 353
         EclipseStarter.run(String[], Runnable) line: 180
         NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
         NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available
         DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available
         Method.invoke(Object, Object...) line: not available
         Main.invokeFramework(String[], URL[]) line: 629
         Main.basicRun(String[]) line: 584
         Main.run(String[]) line: 1438
         Main.main(String[]) line: 1414
         owns: TransactionImpl  (id=219)
         owns: CDOTransactionImpl  (id=139)
         waiting for: Object  (id=220)
         Object.wait(long) line: not available [native method]
         Object.wait() line: 503
         ThreadJob.waitForRun(ThreadJob, IProgressMonitor, InternalJob, Thread) line: 270
         ThreadJob.joinRun(ThreadJob, IProgressMonitor) line: 197
         ImplicitJobs.begin(ISchedulingRule, IProgressMonitor, boolean) line: 92
         JobManager.beginRule(ISchedulingRule, IProgressMonitor) line: 286
         Lock.uiSafeAcquire(boolean) line: 359
         DawnDiagramEditingDomainFactory$DawnDiagramEditingDomain(TransactionalEditingDomainImpl).acquire(InternalTransaction) line: 580
         DawnDiagramEditingDomainFactory$DawnDiagramEditingDomain(TransactionalEditingDomainImpl).activate(InternalTransaction) line: 508
         TransactionImpl.start() line: 204
         DawnDiagramEditingDomainFactory$DawnDiagramEditingDomain(TransactionalEditingDomainImpl).startTransaction(boolean, Map<?,?>) line: 424
         DawnDiagramEditingDomainFactory$DawnDiagramEditingDomain(TransactionalEditingDomainImpl).runExclusive(Runnable) line: 321
         DawnDiagramUpdater.refreshEditPart(EditPart, DiagramDocumentEditor) line: 80
         DawnGMFHandler.handleObject(CDOObject) line: 236
         DawnGMFHandler.handleViewInvalidationEvent(CDOViewInvalidationEvent) line: 80
         DawnGMFHandler(BasicDawnListener).notifyEvent(IEvent) line: 54
         Notifier.fireEventSafe(IEvent, IListener[]) line: 167
         CDOTransactionImpl(Notifier).fireEvent(IEvent, IListener[]) line: 113
         CDOTransactionImpl(CDOViewImpl).fireInvalidationEvent(long, Map<CDOObject,CDORevisionDelta>, Set<CDOObject>) line: 984
         CDOTransactionImpl(CDOViewImpl).doInvalidate(CDOBranch, long, List<CDORevisionKey>, List<CDOIDAndVersion>, Map<CDOID,InternalCDORevision>, boolean) line: 873
         CDOViewImpl$InvalidationRunnable.run() line: 1709
         CDOViewImpl$2(QueueRunner).work(Worker$WorkContext, Runnable) line: 26
         CDOViewImpl$2(QueueRunner).work(Worker$WorkContext, Object) line: 1
         CDOViewImpl$2(QueueWorker<E>).doWork(Worker$WorkContext) line: 78
         CDOViewImpl$2(QueueWorker<E>).work(Worker$WorkContext) line: 70
         Worker$WorkerThread.run() line: 209
Re: [CDO/Dawn] Deadlocking w/ Display, Dawn's handleViewInvalidationEvent, &amp; CDO's Invalidat [message #1242285 is a reply to message #1237458] Sun, 09 February 2014 09:15 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Hi Josh,
Sorry, I'm not a Dawn expert (and especially not the responsible for Dawn). Display.syncExec() is often problematic and
can easily lead to deadlocks. If you can provide me with a test case that reproduces the deadlock after a reasonable
number of runs I'm certainly willing to analyze it.
Cheers
/Eike
http://www.esc-net.de
Am 29.01.2014 20:34, schrieb Josh M:
> org.eclipse.equinox.launcher.Main at localhost:57194 Thread [main] (Suspended) owns: RunnableLock
> (id=138) waiting for: CDOTransactionImpl (id=139) owned by: Thread
> [CDOViewInvalidationRunner-Transaction 6] (Suspended) CDOStoreImpl.remove(InternalEObject,
> EStructuralFeature, int) line: 479 CDOLegacyAdapter.notifyRemove(EStructuralFeature, int) line: 250
> CDOLegacyAdapter.notifyChanged(Notification) line: 125 NodeImpl(BasicNotifierImpl).eNotify(Notification) line:
> 374 ENotificationImpl(NotificationImpl).dispatch() line: 1027
> ConnectorImpl(EdgeImpl).setTarget(View) line: 215 DawnGMFHandler$2$1.doExecute() line: 181
> DawnGMFHandler$2$1(RecordingCommand).execute() line: 135 EMFCommandOperation.doExecute(IProgressMonitor, IAdaptable)
> line: 119 EMFCommandOperation(AbstractEMFOperation).execute(IProgressMonitor, IAdaptable) line: 150
> DawnGMFHandler$2.run() line: 174 RunnableLock.run() line: 35
> UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 135 Display.runAsyncMessages(boolean) line: 4144
> Display.readAndDispatch() line: 3761 Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2701
> Workbench.runUI() line: 2665 Workbench.access$4(Workbench) line: 2499 Workbench$7.run() line: 679
> Realm.runWithDefault(Realm, Runnable) line: 332 Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 668
> IDEApplication.start(IApplicationContext) line: 124 EclipseAppHandle.run(Object) line: 196
> EclipseAppLauncher.runApplication(Object) line: 110 EclipseAppLauncher.start(Object) line: 79
> EclipseStarter.run(Object) line: 353 EclipseStarter.run(String[], Runnable) line: 180
> DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available Method.invoke(Object, Object...)
> line: not available Main.invokeFramework(String[], URL[]) line: 629 Main.basicRun(String[]) line: 584
> Main.run(String[]) line: 1438 Main.main(String[]) line: 1414 Thread
> [CDOViewInvalidationRunner-Transaction 6] (Suspended) owns: TransactionImpl (id=219) owns:
> CDOTransactionImpl (id=139) waiting for: Object (id=220) Object.wait(long) line: not available [native
> method] Object.wait() line: 503 ThreadJob.waitForRun(ThreadJob, IProgressMonitor, InternalJob, Thread) line:
> 270 ThreadJob.joinRun(ThreadJob, IProgressMonitor) line: 197 ImplicitJobs.begin(ISchedulingRule,
> IProgressMonitor, boolean) line: 92 JobManager.beginRule(ISchedulingRule, IProgressMonitor) line: 286
> line: 580
> line: 508 TransactionImpl.start() line: 204
> Map<?,?>) line: 424
> 321 DawnDiagramUpdater.refreshEditPart(EditPart, DiagramDocumentEditor) line: 80
> DawnGMFHandler.handleObject(CDOObject) line: 236 DawnGMFHandler.handleViewInvalidationEvent(CDOViewInvalidationEvent)
> line: 80 DawnGMFHandler(BasicDawnListener).notifyEvent(IEvent) line: 54 Notifier.fireEventSafe(IEvent,
> IListener[]) line: 167 CDOTransactionImpl(Notifier).fireEvent(IEvent, IListener[]) line: 113
> Map<CDOID,InternalCDORevision>, boolean) line: 873 CDOViewImpl$InvalidationRunnable.run() line: 1709
> CDOViewImpl$2(QueueWorker<E>).work(Worker$WorkContext) line: 70 Worker$WorkerThread.run() line: 209
Re: [CDO/Dawn] Deadlocking w/ Display, Dawn's handleViewInvalidationEvent, &amp; CDO's Invalidat [message #1711921 is a reply to message #1242285] Tue, 20 October 2015 10:02 Go to previous messageGo to next message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
I'd like to revive this subject because it's still occurring on our application(sirius and sirius client) and even it is reproductible in particular conditions we are talking about deadlock so it is a major issue for us
I have similar stackTraces
Scenario:
1- execute an EMFCommand which lasts long enough to do step2 (for example open a DialogBox in the Command which require user to close it)
2- meanwhile do some modification on CDO server. Then the CDOViewInvalidationRunner thread will do some stuff on the client.
Step1 is executed on UIThread and will require CDOTransaction to apply changes
Step2 : In CDOViewInvalidationRunner thread, CDOViewImpl.doInvalidate takes the lock on CDOTransaction. If an EMFCommand is executed, during step2, it'll require the lock on UI because of TransactionalEditingDomainImpl.acquire which call Lock.uiAcquire as pointed out by Josh
The problem comes from that.
Why does TransactionalEditingDomainImpl.acquire need to call
transactionLock.uiSafeAcquire(!tx.isReadOnly());
EMFTransaction should not rely on the UIThread.
The https://bugs.eclipse.org/bugs/show_bug.cgi?id=375161 bug is opened to handle this issue.
In that ticket, Esteban DUGUEPEROUX, proposed to call
transactionLock.acquire(!tx.isReadOnly());
What do you think?
Thank a lot for your answer.
Laurent Fasani - Obeo
Re: [CDO/Dawn] Deadlocking w/ Display, Dawn's handleViewInvalidationEvent, &amp;amp; CDO's Inval [message #1711944 is a reply to message #1711921] Tue, 20 October 2015 11:44 Go to previous message
Am 20.10.2015 um 12:02 schrieb Laurent Fasani:
> Hello
It seems to me that you want to revive this discussion with the EMF Transaction team, right? If so, I'd suggest you
start a new thread in this forum and don't use the prefix [CDO]. That will hopefully attract their experts...
Cheers
/Eike
> Scenario: 1- execute an EMFCommand which lasts long enough to do step2 (for example open a DialogBox in the Command
> client.
> Why does TransactionalEditingDomainImpl.acquire need to call transactionLock.uiSafeAcquire(!tx.isReadOnly());
> In that ticket, Esteban DUGUEPEROUX, proposed to call transactionLock.acquire(!tx.isReadOnly());
> What do you think?
Previous Topic: [XCore] xtend-maven-plugin used with tycho don't generate sources on JENKINS
Next Topic:Deadlock in EMF transaction
Current Time: Sat Jan 23 04:26:59 GMT 2021
Powered by FUDForum. Page generated in 0.01714 seconds
