JFace-Databinding [message #1236928] |
Tue, 28 January 2014 07:17  |
I'm trying to create my first JFace-Databinding application. I am working from these tutorials:
http://www.vogella.com/tutorials/EclipseDataBindingEMF/article.html
http://tomsondev.bestsolution.at/2009/06/06/galileo-improved-emf-databinding-support/
What I don't understand is as follows:
I have created an EMF model and generated all the code. I have also built on top of this a GMF application (yes, I know this is the EMF forum, but I'm kind of falling between the crack....)
When I make changes to the GMF diagram (add entity for example), the change is recorded in two files (diagram layout and instance data), all based on the EMF model.
If I now replace the GMF view with a custom built JFace view using databinding as per the above tutorials, how do I first load/create those files and how do I continue to store the updates? I'm assuming via databinding but I just can't understand where to even start with this....
(I know that if I keep the GMF view, I can just "steal" the editingDomain of that view and drive changes that way but if I don't have that view at all....???)
Greg
[Updated on: Tue, 28 January 2014 07:18] by Moderator
Re: JFace-Databinding [message #1236961 is a reply to message #1236928] |
Tue, 28 January 2014 08:47   |
On 28-01-14 13:17, Greg Dart wrote:
There are different ways to go about.
You could simply get an EMF Resource and bind it.
set = new ResourceSetImpl()
set.getResource(URI) => the URI location of your semantic file (Not the
notation from GMF, as this only contains the visual aspects of your model).
.... bind your resource.
Other options involve sharing the EditingDoman, but this is more
complicated. Editing domain sharing is really only interresting if you
want to share the CommandStack (So Undo/Redo works accross mutiple views
or editors).
> Greg
FUDForum. Page generated in 0.24948 seconds
