Home » Newcomers » Newcomers » Apache ODE in eclipse throws sql exception after start
Apache ODE in eclipse throws sql exception after start [message #1236884] Tue, 28 January 2014 04:43 Go to next message
Hi, I configured tomcat, apache ode and eclipse in a right way upto me. But when I start Apache ODE, it starts but after few seconds it throws following exception: (help please???)
Caused by: ERROR 25502: An SQL data change is not permitted for a read-only connection, user or database.
at org.apache.derby.iapi.error.StandardException.newException(Unknown Source)
at org.apache.derby.impl.sql.conn.GenericAuthorizer.authorize(Unknown Source)
at org.apache.derby.impl.sql.execute.GenericResultSetFactory.getUpdateResultSet(Unknown Source)
at org.apache.derby.exe.acf81e0010x0143xd7fcx31e3x000004817a684.fillResultSet(Unknown Source)
at org.apache.derby.exe.acf81e0010x0143xd7fcx31e3x000004817a684.execute(Unknown Source)
at org.apache.derby.impl.sql.GenericActivationHolder.execute(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
Re: Apache ODE in eclipse throws sql exception after start [message #1236887 is a reply to message #1236884] Tue, 28 January 2014 04:48 Go to previous messageGo to next message
This would depend on what the statement is, but are you sure it's specific to when you're running within Eclipse?
Re: Apache ODE in eclipse throws sql exception after start [message #1236981 is a reply to message #1236887] Tue, 28 January 2014 09:37 Go to previous messageGo to next message
Yes Nitin, it occurs when i tried to run within Eclipse.
Re: Apache ODE in eclipse throws sql exception after start [message #1281818 is a reply to message #1236981] Tue, 01 April 2014 07:55 Go to previous message
Hi Muhammad,
are you using Windows 7 and Tomcat/ODE is under Program Files (or Program Files (x86))?
If so, I suggest you uninstall Tomcat from that directory and re-install in a location similar to the following:
C:\dev\Tomcat\
Once installations of both Tomcat and ODE are completed, re-configure Eclipse in order to read from the proper paths.
The root cause for the issue you reported may be found by searching in stackoverflow.com for:
apache Derby - getting java.io.FileNotFoundException: derby.log (Access is denied) when creating new database
P.S: As I currently have less than 5 forum posts, I cannot utilize a URL link.
Previous Topic:Eclipse Executable Cannot Find Companion Shared Library Error (Solution)
Next Topic:Eclipse Class.forname() function
Current Time: Sat Jul 19 11:47:45 EDT 2025
Powered by FUDForum. Page generated in 0.13518 seconds
