Home » Modeling » EMF » How to register ecore file and look up for already registered ones in Eclipse
How to register ecore file and look up for already registered ones in Eclipse [message #1235630] Fri, 24 January 2014 21:11 Go to next message
Hamid Qartal is currently offline Hamid QartalFriend
Member
It happened to me that I alway have problem with eclipse not recognizing my ecore file, since it can not find the appropriate one.
Here is the question :
1- It seems that there is a kind of rep. for the eclipse that ecore file is registered there, so if any program or tool is requiring ecore core file it request eclipse to look for that in that registery and tell him if the file registered or not? Is this true?
2- if 1 is true how I can register my ecore file in this repository (by code and manually, i.e. in eclipse env.)?
3- How can I look up this repository (e.g., list the registered ecore files?
Any clarification is appreciated.
Re: How to register ecore file and look up for already registered ones in Eclipse [message #1240940 is a reply to message #1235630] Fri, 07 February 2014 08:49 Go to previous messageGo to next message
Hamid,
Comments below.
There's EPackage.Registry.INSTANCE and generated models in the
plugin.xml register the Ecore model there via
org.eclipse.emf.ecore.generated_package.
The generator should just produce the correct registration in the
plugin.xml automatically.
> files?
You can inspect the EPackage.Registry.INSTANCE.
> Thanks
Ed Merks
Re: How to register ecore file and look up for already registered ones in Eclipse [message #1696999 is a reply to message #1240940] Sat, 30 May 2015 16:05 Go to previous messageGo to next message
Member
Can you please take a look at this question here. I still could not solve this problem. To be honest, I could not follow your answer; I do not want to create a plugin nor I want to generate a code for my ecore file. I just simply want it to be recognized by eclipse, and then I can refer to that by just using its package URI instead of using relative path or something. Is this possible to do?
Re: How to register ecore file and look up for already registered ones in Eclipse [message #1697011 is a reply to message #1696999] Sun, 31 May 2015 05:36 Go to previous messageGo to next message
Hamid,
Comments below.
> http://stackoverflow.com/questions/30548241/register-an-ecore-in-eclipse-environment.
No, only registered models (one installed into the running IDE or the
Target platform and registered in the bundle's plugin.xml) are available
via their nsURI.
Ed Merks
Re: How to register ecore file and look up for already registered ones in Eclipse [message #1697051 is a reply to message #1697011] Mon, 01 June 2015 08:50 Go to previous message
Maximilian Junker is currently offline Maximilian JunkerFriend
It seems that Epsilon provides a functionality to register EPackages of ecore files in the workspace into the running eclipse instance.
Have a look at this tutorial (section "Register library.ecore"):
https://eclipse.org/epsilon/doc/articles/reflective-emf-tutorial/
I used this function a while ago and it seemed that the registration is persisted.
You will need to install the Epsilon plugin, however (but not create a dedicated plugin yourself).
You can look up registered packages by opening the "EPackage Registry" view.
Maximilian
Previous Topic:[CDO] Audit view on branch before base timestamp
Next Topic:XSDEcoreBuilder / EcoreRefletive Editor : Strange behavior with xsd:element without typetype
Current Time: Tue Jan 19 16:05:01 GMT 2021
Powered by FUDForum. Page generated in 0.01990 seconds
