Home » Language IDEs » ServerTools (WTP) » Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues
Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues [message #201765] |
Wed, 10 October 2007 20:45  |
Werner Keil Messages: 1087 Registered: July 2009 |
I posted this earlier in the Mylyn group, but it does not seem to have
anything to do with Mylyn.
I installed both Eclipse 3.4 M2 and all required dependencies for WTP3.
Then WTP 3.0 M2 (the Runtime, not the SDK)
Random tests like setting up various servers and even the new Visual
JSP/HTML editor work perfectly well.
However, once you try running UpdateManager for every additional plugin
(e.g. Mylyn, it is the same for others like SVN client, etc.) I tried,
this is not possible due to the following errors:
The current configuration contains errors and this operation can have
unpredictable results.
WST Web Services UI (2.0.1.v200710021354-792EGwAufYO8FqYlmS_5Ff4sbiKz)
requires plug-in "org.eclipse.gef (3.2.0)", or compatible.
WTP Web Page Editor (1.1.0.v200709202235-3-29oA55P855A) requires
Java Persistence API Tools (1.1.0.v200709170000-772AgCYQCCz-D_LoCCEH)
requires feature "org.eclipse.datatools.connectivity.feature".
WST Common UI (2.1.0.v200709192200-7C6EIaE9RvTVninpsnWz0WgQZgle)
requires plug-in "org.eclipse.draw2d (3.2.0)", or compatible.
Eclipse XML Editors and Tools
(2.1.0.v200709192200-7A3EIPCnbckz0itrBsMmAKQjdclf) requires plug-in
First of all, most of those dependencies point as far back to 3.2.0 (?)
Second of all, some important parts mentioned here, like WTP Web Page
Editor work perfectly fine in tests with web pages.
Would this error be true, I'd expect the editor to not even work.
If you completely remove WTP 3 or install 3.4 M2 on its own, plugins
like Mylyn install with no problem.
Please advise, this seems like a significant problem. I understand, 3 is
probably still a very early release, so I may have to go with 2.x at
least for a production-like system.
Once I get Mylyn up and running somewhere, I guess I will also file the
bug there in Bugzilla.
Re: Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues [message #201910 is a reply to message #201765] |
Thu, 11 October 2007 17:59   |
David Williams Messages: 722 Registered: July 2009 |
On Wed, 10 Oct 2007 16:45:40 -0400, Werner Keil <werner.keil@gmx.net> wr=
ote:
> Please advise, this seems like a significant problem. I understand, 3 =
is
I'm a little confused by some of the behavior you are reporting, and you=
don't say where you are getting your updates from .... but, I do know th=
ey
don't exist for WTP 3.0 M2 ... so, I'll assume that's the only problem, =
for now.
I've opened but 206070 to track.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D206070
It'll take me a day or so to do for M2, but we do plan to make our updat=
es
available on an update site, but it will be a special one you'll have to=
add to your update manager as a new remote site:
http://download.eclipse.org/webtools/milestones/
The reason, if you're interested, is that we don't want to risk someone
using a production release of a product built on WTP 2.0 getting the wro=
ng unreleased
version of WTP installed in their product (in a perfect world, there'd b=
e no risk ... but,
we all know update manager :)
I do appreciate you letting us know you want/need this. Thank you.
Re: Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues [message #204542 is a reply to message #204291] |
Fri, 16 November 2007 06:56   |
On Tue, 13 Nov 2007 03:50:38 -0500, Gabriele Garuglieri <gabriele.garuglieri@infoblu.it> wrote:
> I reiterate the question, which was not answered.
> The milestones update site only contains 2.1 stuff. No 3.0 updates
> anywhere.
> As far as i know this is the only project that still requires manual
> download and installation to follow milestones builds and this is a real
> pain.
> We do our best to try and test new releases, but please on your side
> please help us to stay current making milestones/interim builds available
> via update manager like all the other eclipse projects do.
> Thanks, Gabriele
That 2.1 stuff you see is the 3.0 stream "in progress", so should work fine.
Give it a try.
We'll occationally bump up the 2.x versions, but based on your experience, maybe
we should just go all the way to 3.0 next milestone.
Current Time: Thu Aug 18 18:01:06 GMT 2022
Powered by FUDForum. Page generated in 0.02002 seconds
