Generating JAVA classes from XSDs [message #19283] |
Thu, 01 May 2003 18:13 |
Originally posted by: spambort.rogers.com
Hi all
Is there a way that I can take an XSD and generate JAVA classes that would
allow me to access the data within a corresponding XML document?
Also, given an XSD, can I have Eclipse generate a sample/dummy XML file?
bort
Re: Generating JAVA classes from XSDs [message #19327 is a reply to message #19283] |
Thu, 01 May 2003 19:26 |
--------------A27EC63B787447444C733212
Content-Type: text/plain; charset=us-ascii
Bort,
Yes, if you follow the tutorials in the EMF subproject
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/clibmod/clibmod_main.html
you'll find that you can do an import from XML Schema as opposed to importing
from a Rose model. (If all goes well, later today there should be a new
tutorial avaiable that deals explicitly with generating from an XML Schema.)
There isn't a tool to generate instance files in Eclipse. WSAD has such a
tool Perhaps IBM's alphaworks has something like that as well. If you follow
the steps above to create an EMF model, you can also create a sample editor
and that sample editor will be able to create an instance file...
bort wrote:
> Hi all
> bort
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Bort,
<p>Yes, if you follow the tutorials in the EMF subproject
<blockquote> <a href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/clibmod/clibmod_main.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/clibmod/clibmod_main.html</a></blockquote>
a new tutorial avaiable that deals explicitly with generating from an XML
Schema.)
<p>There isn't a tool to generate instance files in Eclipse. WSAD
has such a tool Perhaps IBM's alphaworks has something like that
as well. If you follow the steps above to create an EMF model, you can
also create a sample editor and that sample editor will be able to create
an instance file...
<p>bort wrote:
<blockquote TYPE=CITE>Hi all
<p>Is there a way that I can take an XSD and generate JAVA classes that
would
<br>allow me to access the data within a corresponding XML document?
<p>Also, given an XSD, can I have Eclipse generate a sample/dummy XML file?
<p>bort</blockquote>
</html>
--------------A27EC63B787447444C733212--
Re: Generating JAVA classes from XSDs [message #568748 is a reply to message #19283] |
Ed Merks Messages: 33137 Registered: July 2009 |
Bort,
bort wrote:
> Hi all
> bort
<html>
Bort,
Schema.)
an instance file...
would
</html>
Ed Merks
FUDForum. Page generated in 0.03594 seconds
