Re: Installation Directions for OHF Bridge [message #20722 is a reply to message #19265] |
Wed, 04 October 2006 10:38 |
Originally posted by: Martin.Ahrer.gmx.at
I'd like to set up a local OHF bridge. Is there an updated version of
the installation instructions. I'm trying to set up with a current CVS
version and I have figured that the procedure from
http://wiki.eclipse.org/index.php/Bridge_Install_Steps does not quite fit!
I'm getting some errors while exporting the eclipse plugins...
org.eclipse.ohf.ihe.xds.consumer does not find
org.eclipse.ohf.ihe.xds.soap.* classes while I feel that I have followed
the instructions!
Is there any timeline as when pre-built binaries will be posted to some
download server?
Martin
Melih Onvural schrieb:
> I'd like to announce the initial set of instructions for installing the
> OHF Bridge. Please note that this works with code checked in as of
> August 16th. There has been one code check in since then, and there are
> some integration kinks being worked out. It is possible within CVS to
> check out code only checked in by a certain date, and I would suggest
> this technique until all of the kinks are ironed out. I will announce
> when this happens, and update the install instructions accordingly. The
> link is here:
> http://wiki.eclipse.org/index.php/Ohf_bridge#Bridge_Install_ Steps
> Melih
Re: Installation Directions for OHF Bridge [message #20751 is a reply to message #20722] |
Wed, 04 October 2006 23:13 |
Originally posted by: eishays.us.ibm.com
We can't publish the link yet. Should be public after some legal process
is over.
You may get the PHP client app from the CVS (nothing to compile there).
Its available at:
http://ibmod235.dal-ebis.ihost.com:8080
You may also just use the public installation we have. We are updating
it with bugfix and there are few ISVs that use it:
http://ibmod235.dal-ebis.ihost.com:8090/bridge/services/ohf- bridge?wsdl
--eishay
> the instructions!
> download server?
> Thanks
> Martin
>> the OHF Bridge. Please note that this works with code checked in as of
>> are some integration kinks being worked out. It is possible within CVS
>> to check out code only checked in by a certain date, and I would
>> suggest this technique until all of the kinks are ironed out. I will
>> announce when this happens, and update the install instructions
>> accordingly. The link is here:
>> Melih
FUDForum. Page generated in 0.04184 seconds
