Home » Archived » Buckminster » Executing plugIn unit tests with buckminster headless
Executing plugIn unit tests with buckminster headless [message #1233845] Mon, 20 January 2014 16:29 Go to next message
Felix Feisst is currently offline Felix FeisstFriend
I try to execute some plugIn tests with buckminster headlessly. However, when buckminster trys to execute the launch configuration with the junit command, the following error occurs:
[INFO] Launch configuration type id "org.eclipse.pde.ui.JunitLaunchConfig" does not exist.
[INFO] Possible causes:
[INFO]  Missing specification of a launch type (missing plug-in)
[INFO]  Incorrect launch configuration XML
My launch configuration looks like this:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.JunitLaunchConfig">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="askclear" value="false"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="true"/>
<booleanAttribute key="clearws" value="true"/>
<booleanAttribute key="clearwslog" value="false"/>
<stringAttribute key="configLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/pde-junit"/>
<booleanAttribute key="default" value="true"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="location" value="${workspace_loc}/../junit-workspace"/>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_PATHS">
<listEntry value="/plugin.test"/>
</listAttribute>
<listAttribute key="org.eclipse.debug.core.MAPPED_RESOURCE_TYPES">
<listEntry value="4"/>
</listAttribute>
<stringAttribute key="org.eclipse.jdt.junit.CONTAINER" value="=plugin.test"/>
<booleanAttribute key="org.eclipse.jdt.junit.KEEPRUNNING_ATTR" value="false"/>
<stringAttribute key="org.eclipse.jdt.junit.TESTNAME" value=""/>
<stringAttribute key="org.eclipse.jdt.junit.TEST_KIND" value="org.eclipse.jdt.junit.loader.junit4"/>
<stringAttribute key="org.eclipse.jdt.launching.JRE_CONTAINER" value="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6"/>
<stringAttribute key="org.eclipse.jdt.launching.MAIN_TYPE" value=""/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -consoleLog"/>
<stringAttribute key="org.eclipse.jdt.launching.PROJECT_ATTR" value="plugin.test"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="pde.version" value="3.3"/>
<stringAttribute key="product" value="org.eclipse.sdk.ide"/>
<booleanAttribute key="run_in_ui_thread" value="true"/>
<booleanAttribute key="show_selected_only" value="false"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useCustomFeatures" value="false"/>
<booleanAttribute key="useDefaultConfig" value="true"/>
<booleanAttribute key="useDefaultConfigArea" value="false"/>
<booleanAttribute key="useProduct" value="true"/>
</launchConfiguration>
Any help is appreciated! Thanks,
Felix
Re: Executing plugIn unit tests with buckminster headless [message #1233849 is a reply to message #1233845] Mon, 20 January 2014 16:40 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
On 20/01/2014 17:29, Felix Feisst wrote:
> Hello,
Hi Felix
you must install org.eclipse.buckminster.pde.headless.feature in your
buckminster headless installation.
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Executing plugIn unit tests with buckminster headless [message #1233925 is a reply to message #1233845] Mon, 20 January 2014 21:16 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Felix,
What version are you using? IIRC, the ui dependency in the launch config has been removed for quite a while. It was
removed because you really want to be able to launch headlessly.
- thomas
On 2014-01-20 17:29, Felix Feisst wrote:
> Hello,
> </listAttribute>
> </listAttribute>
> Felix
Re: Executing plugIn unit tests with buckminster headless [message #1236841 is a reply to message #1233925] Tue, 28 January 2014 07:41 Go to previous message
Thank you so far, installing org.eclipse.buckminster.pde.headless.feature into my buckminster installation solved the problem so far.
However, I do get a follow up error now. When buckminster trys to run the launch configuration an error occurrs. In the corresponding log I found:
java.lang.RuntimeException: Application "org.eclipse.pde.junit.runtime.nonuithreadtestapplication" could not be found in the registry.
I have change the attribute "run_in_ui_thread" in the launch configuratin to false, having this attribute on true gives a similar error.
Previous Topic:Headless build for Java-8 applications
Next Topic:Cross-platform builds with buckminster 4.3
Current Time: Tue Aug 03 21:59:54 GMT 2021
Powered by FUDForum. Page generated in 0.02094 seconds
