Home » Language IDEs » ServerTools (WTP) » IWAB0489E Error when deploying Web service to Axis
IWAB0489E Error when deploying Web service to Axis [message #201040] Tue, 02 October 2007 13:56 Go to next message
Originally posted by: listacctc.gmail.com
I keep getting this error when trying to deploy a test service:
IWAB0489E Error when deploying Web service to Axis runtime
axis-admin failed with {http://xml.apache.org/axis/}HTTP
(404)/EbizLDAPSoa/services/AdminService
I've actually done this sucessfully a couple of times already so why its
deciding to be difficult now is confusing. I tried performing an update
to eclipse to see if something might have changed but that had no effect.
I googled around and this problem has been reported in the past but I've
not found any solutions that worked. Does anybody have any ideas?
Thanks - Tod
Eclipse Platform
Version: 3.3.0
Build id: M20070921-1145
Re: IWAB0489E Error when deploying Web service to Axis [message #201136 is a reply to message #201040] Wed, 03 October 2007 17:36 Go to previous messageGo to next message
Answering my own question.
Copy the java code somewhere, delete the project, recreate it, import
the code. This worked because my project was small and had fewer
dependencies - YMMV
- Tod
> Thanks - Tod
> Eclipse Platform
> Version: 3.3.0
Re: IWAB0489E Error when deploying Web service to Axis [message #201285 is a reply to message #201136] Thu, 04 October 2007 19:33 Go to previous messageGo to next message
Kathy Chan is currently offline Kathy ChanFriend
Member
Glad that you've found a workaround. If you run into this problem again,
please check the following:
1. Verify that the web.xml of the dynamic Web project has been updated with
the Axis2 servlet.
2. The project has been added to the server and the server state is started.
3. Ping the URL "<your_project_context_root>/services/AdminService"
(e.g."http://localhost:8080/WebProj/services/AdminService) and verify that
the Axis2 servlet is up and running.
4. Ensure that deploy.wsdd is generated in the Web project's
WebContent/WEB-INF directory under the package name.
What the tool does at this point is call the Axis AdminClient tool.
If all the above did not indicate a problem and you are still having a
problem with Axis deploy, please open a bugzilla with detail info on how to
reproduce the problem and may be attach the workspace.
Thanks!
Kathy Chan
"List Acctc" <listacctc@gmail.com> wrote in message
news:fe0jvt$49c$1@build.eclipse.org...
> Copy the java code somewhere, delete the project, recreate it, import the
> dependencies - YMMV
> - Tod
>> Thanks - Tod
>> Eclipse Platform
>> Version: 3.3.0
Re: IWAB0489E Error when deploying Web service to Axis [message #201359 is a reply to message #201285] Fri, 05 October 2007 12:44 Go to previous messageGo to next message
> the Axis2 servlet.
Will do, thanks!
Re: IWAB0489E Error when deploying Web service to Axis [message #201397 is a reply to message #201359] Sun, 07 October 2007 04:11 Go to previous messageGo to next message
mark streit is currently offline mark streitFriend
Are we sure this user is using Axis2 because I have seen this exact error
when using Axis1 - the Axis 1.4 implementation that ships w/ WTP. The error
does not occur all the time either. My work around was to kill the original
project in the workspace and start all over, including deleting and
re-adding the Tomcat 5.5 server instance in the Server View...frustrating to
say the least.
news:fe5bk8$omn$1@build.eclipse.org...
>> with the Axis2 servlet.
>> started.
>> that the Axis2 servlet is up and running.
> Will do, thanks!
Re: IWAB0489E Error when deploying Web service to Axis [message #201579 is a reply to message #201397] Tue, 09 October 2007 13:49 Go to previous messageGo to next message
Member
Yes. I made a typo. I meant to say Axis1, not Axis2. This error only
apply to Axis1 since Axis2 uses very different deployment mechanism.
If you run into this problem, could you please note the steps I suggested to
help us try to isolate the problem? Does it happen on the project when you
try creating an Axis1 Web service the first time or on subsequent tries?
"mark" <mcs130@gmail.com> wrote in message
news:fe9m5c$t4c$1@build.eclipse.org...
> error does not occur all the time either. My work around was to kill the
> original project in the workspace and start all over, including deleting
> and re-adding the Tomcat 5.5 server instance in the Server
> View...frustrating to say the least.
>>> again, please check the following:
>>> started.
>> Will do, thanks!
Re: IWAB0489E Error when deploying Web service to Axis - WORKAROUND [message #204927 is a reply to message #201397] Sun, 25 November 2007 13:27 Go to previous message
Jason Harrop is currently offline Jason HarropFriend
I was getting this error today as well. Eventually, I tracked down what
was happening.
The problem is occurring because the create web service wizard in my
freshly installed Eclipse SDK, Version: 3.3.1.1, Build id:
M20071023-1652 is doing:
POST /plutext-server/services/AdminService HTTP/1.0\r\n
User-Agent: Axis/1.4
SOAPAction: "urn:AdminService"
to my Axis2 server, which doesn't have an AdminService:
25.11.2007 18:55:49 *DEBUG* AxisServlet: org.apache.axis2.AxisFault: The
service cannot be found for the endpoint reference (EPR)
http://localhost:8080/plutext-server/services/AdminService
(AxisServlet.java, line 152)
The problem is caused by the presence of plug-in id's
org.eclipse.jst.ws.axis.* being used in preference to
org.eclipse.jst.ws.axis2.*
In
~/.eclipse/org.eclipse.platform_3.3.0_1606436040/configurati on/eclipse/plugins,
I had:
org.eclipse.jst.ws.axis.ui.doc.user_1.0.300.v200706111751.ja r
org.eclipse.jst.ws.axis.infopop_1.0.203.v200708222303.jar
org.eclipse.jst.ws.axis.creation.ui_1.0.205.v200708151945.ja r
org.eclipse.jst.ws.axis.consumption.ui_1.0.203.v200708151945 .jar
org.eclipse.jst.ws.axis.consumption.core_1.0.204.v2007081519 45.jar
org.eclipse.jst.ws.axis2.ui_1.0.1.v200708282350.jar
org.eclipse.jst.ws.axis2.creation.ui_1.0.1.v200708241921.jar
org.eclipse.jst.ws.axis2.creation.core_1.0.1.v200708241921.j ar
org.eclipse.jst.ws.axis2.core_1.0.1.v200709191532.jar
org.eclipse.jst.ws.axis2.consumption.ui_1.0.1.v200709121418. jar
org.eclipse.jst.ws.axis2.consumption.core_1.0.1.v20070824192 1.jar
So I moved the org.eclipse.jst.ws.axis.* and
..metadata/.plugins/org.eclipse.jst.ws.axis.consumption.core out of the way.
Now when I go to create a bottom up web service, I'm getting a page
"Axis2 Web Service Java Bean Configuration". :) And the service is
created properly :)
One note: it is created in WEB-INF/services, not in the directory
specified in the init-param axis2.repository.path to servlet
org.apache.axis2.transport.http.AxisServlet
cheers
Jason
> say the least.
>>> started.
>> Will do, thanks!
Previous Topic:Moving WSAD5 to JBOSS 4.2.1 with eclipse IDE
Next Topic:Corollary to org.eclipse.jst.component.dependency in WTP 1.5
Current Time: Tue Apr 16 04:54:26 GMT 2024
Powered by FUDForum. Page generated in 0.52783 seconds
