Home » Modeling » TMF (Xtext) » Generate of PlantUML code for the model (multiple files)
Generate of PlantUML code for the model (multiple files) [message #1232113] Thu, 16 January 2014 09:06 Go to next message
Simon Ziehme is currently offline Simon ZiehmeFriend
How can i generate PlantUML code for my whole model, not for the current file (mydsl) only?
At the moment I'm using:
override String getDiagramText(IEditorPart editorPart, IEditorInput editorInput) {
        // Retrieve the "semantic" EMF from XtextEditor
        val document = (editorPart as XtextEditor).getDocumentProvider().getDocument(editorInput) as XtextDocument;
        val DomainModel model = document.readOnly[
            return contents.head as DomainModel
Sorry, but I'm a Eclipse/XText/PlantUML newbie Embarrassed
Thanks Simon
Re: Generate of PlantUML code for the model (multiple files) [message #1232169 is a reply to message #1232113] Thu, 16 January 2014 10:54 Go to previous messageGo to next message
Uli Merkel is currently offline Uli MerkelFriend
have a look at "allContents" I think (depending on the ScopeProvider) this will access all the DSLs in the workspace.
This example is from the XTEXT Project
// fsa.generateFile('greetings.txt', 'People to greet: ' +
// resource.allContents
// .filter(typeof(Greeting))
// .map[name]
// .join(', '))
Re: Generate of PlantUML code for the model (multiple files) [message #1232191 is a reply to message #1232169] Thu, 16 January 2014 11:57 Go to previous messageGo to next message
But, how can I access to allContents?
Re: Generate of PlantUML code for the model (multiple files) [message #1232234 is a reply to message #1232113] Thu, 16 January 2014 13:36 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven EfftingeFriend
For code generation the proper hook is IGenerator.
Or do you want to get PlantUML file on the fly to show it in a view,
i.e. see the dirty editor's state as a diagram?
Also what is the 'whole model'? How do you know which files contribute
to that?
Am 16/01/14 10:06, schrieb Simon Ziehme:
> file (mydsl) only?
> editorInput) {
> XtextDocument;
> Sorry, but I'm a Eclipse/XText/PlantUML newbie :blush:
> Thanks Simon
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Generate of PlantUML code for the model (multiple files) [message #1232240 is a reply to message #1232234] Thu, 16 January 2014 13:52 Go to previous messageGo to next message
Sorry for my bad english.
I have a model (mydsl) with interfaces, components, layer ...
DomainModel:
	(types+=Type)*
	(layer+=Layer)*
	(threads+=ParentThread)*
	(interfaces+=Interface)*
	(components+=Component)*
	(applications+=Application)*;
Now i have e.g. many different files (*.mydsl)
One file for each component and so one p.p.
Code generation works fine for me.
Now i need one PlantUML diagram for all files togehter to visualize my (component) model.
Thx Simon
Re: Generate of PlantUML code for the model (multiple files) [message #1232259 is a reply to message #1232240] Thu, 16 January 2014 14:34 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
http://kthoms.wordpress.com/2011/07/12/xtend-generating-from-multiple-i
nput-models/
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Generate of PlantUML code for the model (multiple files) [message #1232547 is a reply to message #1232259] Fri, 17 January 2014 07:11 Go to previous messageGo to next message
Note, that you are deactivating incremental build with this approach,
that is you will load and process all models on every tiny change.
Alternatively, you could register an explicit action just to generate
the PlantUML model, so you separate that generation from the rest.
Am 16/01/14 15:34, schrieb Christian Dietrich:
> nput-models/
Re: Generate of PlantUML code for the model (multiple files) [message #1232549 is a reply to message #1232547] Fri, 17 January 2014 07:18 Go to previous message
Thanks all.
I think i try to seperate the uml generation from the rest.
Best regards
Simon
Previous Topic:Embedded editor and crossreferncing to surounding EMF model
Next Topic:Error while upgrading xtext 2.1 to 2.5 in Eclipse 3.7
Current Time: Sat Feb 27 23:05:54 GMT 2021
Powered by FUDForum. Page generated in 0.02291 seconds
