Arrange two report items side by side HTML vs. PDF [message #200970] |
Wed, 15 November 2006 14:45 |
Originally posted by: screek.gmx.de
I have some problems arranging two report items side by side (with no space
between them).
Let's say we have 2 labels (simplified example; actually I want to do this
with any report item, for example a label and an image ...):
1. label "please don't wrap this text"
2. label "right beside the first label"
To arrange them side by side I put the labels in a grid (2 columns, 1 row).
By default the 2 columns are distributed evenly at the page's width. That
means there is a huge space between the 2 labels (HTML and PDF output).
There is an option for the grid saying "Can shrink", but it doesn't work as
long as the width of the table is at 100%. Removing the 100% value, the HTML
output looks like expected. Unfortunatelly the PDF output still looks like
before.
I can't use fixed values for the column width's because the text of the 1.
label will be dynamic and shall not be wrapped.
Any ideas how I can do this?
Thanks in advance,
Christian
Re: Arrange two report items side by side HTML vs. PDF [message #201025 is a reply to message #200970] |
Wed, 15 November 2006 19:22 |
I don't know if this will help, but can you create a grid with 2 cols 1 row
and
set the first grid cell (not the label) text alignment to "Right"?
Jason
"Christian Eckert" <screek@gmx.de> wrote in message
news:ejf97b$8dm$1@utils.eclipse.org...
> Hello,
> space between them).
> row). By default the 2 columns are distributed evenly at the page's width.
> That means there is a huge space between the 2 labels (HTML and PDF
> output).
> as long as the width of the table is at 100%. Removing the 100% value, the
> HTML output looks like expected. Unfortunatelly the PDF output still looks
> like before.
> Thanks in advance,
> Christian
Re: Arrange two report items side by side HTML vs. PDF [message #201164 is a reply to message #201025] |
Thu, 16 November 2006 09:31 |
Hello Jason,
unfortunatelly this doesn't help. I think the problem is that the PDF output
doesn't shrink the table's width. For now I put up with it. But perhaps
there are other ideas?
Christian
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:ejfpd6$bck$1@utils.eclipse.org...
>and
> Jason
>> Hello,
>> this with any report item, for example a label and an image ...):
>> width. That means there is a huge space between the 2 labels (HTML and
>> PDF output).
>> the HTML output looks like expected. Unfortunatelly the PDF output still
>> looks like before.
>> 1. label will be dynamic and shall not be wrapped.
>> Thanks in advance,
>> Christian
FUDForum. Page generated in 0.03777 seconds
