creating a new key combination for a WTP command [message #200896] |
Mon, 01 October 2007 18:57 |
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
How would I do this? Can I unzip a jar to edit the plugin.xml? If so, which jar
would it be and what command for mapping a key combination to the 'publish'
button on the servers view?
Adam
Re: creating a new key combination for a WTP command [message #201430 is a reply to message #200896] |
Sun, 07 October 2007 16:37 |
> which jar would it be and what command for mapping a key combination to
> the 'publish' button on the servers view?
AFAIK I should be able to go into one of the WTP jars in the eclipse
installation to configure my desired key combination to the appropriate WTP
plugin.xml file.
Am I totally misguided here? Any answer would be most welcome.
Re: creating a new key combination for a WTP command [message #201757 is a reply to message #201437] |
Wed, 10 October 2007 20:05 |
>>> to the 'publish' button on the servers view?
>> appropriate WTP plugin.xml file.
> You can create a custom binding for any command. You don't have to
> modify jars, or plugin.xml files to do this. Just do a search in the
> Eclipse help for "key bindings" or "assigning custom key bindings". This
> should get you going.
Well I hope you can create a custom binding for any command, but it's not in the
General->Keys menu, even if you check the "include unbound commands" and
uncheck all the advanced filter options.
This Keys menu /just doesn't contain/ the 'publish' button.
Check it out.
I am asking about jars and plugin.xml files because that's what I was told would
be the most likely solution (on another eclipse list).
But thanks for answering! I was beginning to think this must be some sort of
taboo subject.
Adam
FUDForum. Page generated in 0.04044 seconds
