How can I run my gef design? [message #200819] |
Thu, 27 October 2005 15:00  |
Originally posted by: ciulbecca.yahoo.it
I have designed my model,I have created my
XYZcreationWizard,XYZEditor,XYZActionBarContributor,XYZconte xtMenuProvider,XYZPaletteFactory,XYZplugIn,the
packages command and parts...now what must I do to run the projet?
...I have lunch "run as Eclipse application"but after the opening
workbench i don't know what do(the plugIn exist in the plugin's list and
is the only trace of my project in all "new"workbench!!)
Re: How can I run my gef design? [message #200921 is a reply to message #200819] |
Fri, 28 October 2005 05:44   |
In the file MANIFEST.MF you can add your editor as an extension and in
the "Extension Element Details" Tab you have to fill in the
extensions-property of your editor. The name you filled in there, is the
Extension of your editor-file. After done this, lunch your editor
with "run as Eclipse application", create a new simple project and then
create an new file with the right extension e.g. "test.XYZEditor" when
you have filled in "XYZEditor" in the extension-property. Then your
editor should start up.
Re: How can I run my gef design? [message #201091 is a reply to message #201082] |
Fri, 28 October 2005 15:40  |
>> iHave not a plugin.xml...I have created a new empty project with my
>> packages..
> if in the package explorer, u right click on the folder ,there u find
> PDE tools, do u have a "convert to plugin projects" if so this will
> create a manifest.xml
> HTH
> kind regards
> Astrid
manifest.mf (sorry typo)
FUDForum. Page generated in 0.08018 seconds
