Home » Eclipse Projects » NatTable » Autoresize command
Autoresize command [message #1231222] Tue, 14 January 2014 05:12 Go to next message
Testr t is currently offline Testr tFriend
Member
I am trying to use the nattable grids autoresize command and it works except that it does not resize the header row's column width. Is there something that I am doing wrong?
	nt.addListener(SWT.Paint, new Listener()
			            boolean resized = false;
                        public void handleEvent( Event event )
                            if ( resized )
                                return;
                            resized = true;
                            for ( int i = 0; i < nt.getColumnCount(); i++ )
                                InitializeAutoResizeColumnsCommand columnCommand = new InitializeAutoResizeColumnsCommand( nt.getLayer(), i, nt.getConfigRegistry(), new GCFactory( nt ) );
                                nt.doCommand(new AutoResizeColumnsCommand( columnCommand ) );
Initially i tried only InitializeAutoResizeColumnsCommand and later read the documentation on AutoResizeColumnsCommand but it does not work either.
Re: Autoresize command [message #1231263 is a reply to message #1231222] Tue, 14 January 2014 07:58 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
I guess you mean the row header column width, right?
The reason is quite easy, the row header does not support auto resizing. This is because the InitializeAutoResizeColumnsCommandHandler is registered against the SelectionLayer. And the AutoResizeColumnCommandHandler that is registered against the GridLayer is performing position-index transformation against the body layer stack.
To provide auto resizing of the row header you will need to implement a custom command and command handler that fits your needs. You could have a look at the current implementations and copy/modify them to not performing position-index transformations for example.
I usually suggest to not calling auto resize at startup but configure the sizes correctly or useing TextPainter that calculate their width. That fits better into a virtual table approach and does not cause performance issues.
Previous Topic:Mixing Sort by and Filter in nattable
Next Topic:Command for setting ComboBoxCellEditor-Values?
Current Time: Sat Jun 06 15:06:59 GMT 2020
Powered by FUDForum. Page generated in 0.02024 seconds
