Unresolved compilation problem [message #1231155] |
Tue, 14 January 2014 00:06 |
I have a Composite (MyForm) with a call to a static method in a utility class (MySendBusiness), like this:
MySendResponse response = MySendBusiness.checkInputData(this);
public static MySendResponse checkInputData(MyForm myForm) {
when I launch it from the IDE all is working well (the utility method is executed), but when I export the WAR and deploy on Tomcat, the method is never executed, without any error on Tomcat console.
So I debugged Tomcat remotely and saw that when the method is called, if stepping-into with debugger, I get to an error in
org.eclipse.swt.widgets.Display.safeReadAndDispatch()
The error says: "Unresolved compilation problem."
What could be the cause?
(Note: I am using the same version of JDK6, both for the IDE and for Tomcat)
Thank you
Vincenzo
Re: Unresolved compilation problem [message #1233008 is a reply to message #1231559] |
Sat, 18 January 2014 10:31 |
we get a little ahead on this issue.
The web service client classes were in a separate source folder (let's say 'src_ws'), instead of the standard 'src' folder (the new source folder was created with the 'New, Source folder' action from the IDE).
Moving these sources into 'src' folder made disappear the 'Unresolved compilation problem'.
Thank you
Vincenzo
FUDForum. Page generated in 0.03525 seconds
