Re: Drag and drop into the SSE [message #200474 is a reply to message #200434] |
Tue, 25 September 2007 08:55 |
Brian Jakubik wrote:
> On the Europa release, when I drag and drop in the editor from the
> navigator, It inserts it one less than where I drop it,
> for example I start with:
> <test id="test1"></test>
> dnd from the navigator and dropping after the last > will give me
> <test id="test1"></test"WebContent/NewFile4.xml">
> this is what I expected (works in 1.x):
> <test id="test1"></test>"WebContent/NewFile4.xml"
> In 1.x of WTP I saw the expected behavior. Is this working as designed
> or a bug. If the latter, let me know and Ill write it up.
It works fine with 3.4 M2, so strangely there was a change in
behavior in the base that fixes the problem for us but which doesn't
seem to affect the default drag and drop support either way. Our
own DND classes haven't been touched since before 2.0 was released,
but changes in when StyledText.getOffsetAtLocation(Point) throws
Exceptions might be responsible. Please open a bug, but it's not
catastrophic enough for 2.0.1 at this point.
Nitin Dahyabhai
Structured Source Editing
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03022 seconds
