Home » Modeling » EMF » EMF and dynamic meta-models
EMF and dynamic meta-models [message #1229982] |
Fri, 10 January 2014 18:20 |
Patrick Tournet Messages: 17 Registered: July 2009 Location: Aix-en-Provence, FRANCE |
Hello everyone,
I'm currently project manager of a C++ developed modeling tool based on an extensible meta-model : at runtime, users can modify (CRUDing classes, relationships, properties, ...) the meta-model and use instantly those modifications in their models.
There's a plan to port it to the Eclipse platform, so I'm gathering as much information as possible to decide the forthcoming software architecture... and that's how I came to take a look at EMF, as it's better to use existing projects (especially when then come with a lot of tools) instead of having to reinvent the wheel (or at least re-develop something from scratch).
From what I've understood, the usual way of use of EMF, is to design a meta-model with ecore (I've seen there are already UML and BPMN ones that have been implemented here), then to generate the Java classes from a genmodel, extend/implement them, then use all that for your model.
My concern is that, if I'm correct, any modification of a meta-model implies a new build and therefore cannot be made by a final user... My idea is, so far, to create a meta-meta-model with EMF (making ecore a meta-meta-meta-model instead of a classic meta-meta-model in MDE 4 layered architecture) that will implement all the shared capabilities(multilingual strings, versioning, ...) the derived meta-models will inherit.
This way it seems to me that I should achieve the ability to design meta-models at runtime while being able to use related projects if needed (CDO, MDT, GMF, ...). But, as I'm new to all of these technologies, it might not be the best way to do it, or there might already be existing ways to do so. So any input would be much appreciated !
I can do anything and I can do it better than anyone. Be as I am : be the best !
Re: EMF and dynamic meta-models [message #1230172 is a reply to message #1229982] |
Sat, 11 January 2014 06:46 |
Ed Merks Messages: 33140 Registered: July 2009 |
Patrick,
Comments below.
On 10/01/2014 7:21 PM, Patrick TOURNET wrote:
> Hello everyone,
Certainly less work!
Yes, that's the typical common use case.
Yes, a generate model cannot be changed at runtime, but it can be
dynamically extended (i.e., via a new EPackage with new EClasses) with a
few limitations. E.g., you can't extend a generated abstract class with
a concrete class, and you can't extend multiple generated classes. In
other words, you can only dynamically extend at most one concrete
class. And of course you can have
Given that Ecore directly supports dynamic models, i.e., you can create
Ecore models on the fly and instantiate instances that conform that that
model, this too might be reinventing the wheel.
http://www.ibm.com/developerworks/library/os-eclipse-dynamicemf/
Most of the infrastructure in the Eclipse modeling ecosystem rely on
working with EObjects (instance) whose meta model is Ecore.
Ed Merks
Re: EMF and dynamic meta-models [message #1230225 is a reply to message #1230172] |
Sat, 11 January 2014 10:59 |
Ed Willink Messages: 7655 Registered: July 2009 |
Comments in line.
>> your model.
There are an increasing number of modeling applications working solely
with dynamic models/meta-models, and some tools now allow you to change
the meta-model dynamically too.
Ed Willink
Re: EMF and dynamic meta-models [message #1231448 is a reply to message #1230172] |
Tue, 14 January 2014 17:57 |
Thank you, Ed,
Ed Merks wrote on Sat, 11 January 2014 07:46Patrick TOURNET wrote on Fri, 11 January 2014 19:21
Unfortunately, you didn't finish your last sentence. I really wonder what it is...
So, if I get it right, the limitation is that you can only extend one class. Is it per package ? (if you're using the UML meta-model, would it be ok to extend "Class" and "Actor" as they're not in the same package (well at least in the XMI definition file) ?
Is there a document that lists those model extension limitations ?
I've seen there"s also another modeling project, called "EMF Facet", that could allow to achieve a meta-model extension. Do you have any take on that ?
I'll be looking into that more deeply...
My take was that as long as you're working with extensions of EObjects (even through indirect extension (extension of an extension)), everything should still work... no ?
Ed Willink wrote on Sat, 11 January 2014 11:59
We've been doing this for more than 28 years now, so I know that exists...
Do you have any reference for such an Eclipse based tool ?
Re: EMF and dynamic meta-models [message #1231649 is a reply to message #1231448] |
Wed, 15 January 2014 06:06 |
Patrick,
Comments below.
On 14/01/2014 6:57 PM, Patrick TOURNET wrote:
> Thank you, Ed,
>> final user...
>> with a few limitations. E.g., you can't extend a generated abstract
>> class with a concrete class, and you can't extend multiple generated
>> classes. In other words, you can only dynamically extend at most one
>> concrete class. And of course you can have
> what it is...
Cut and paste error...
You can only dynamically extend one generated class (and that class
can't be abstract) because a dynamic extension relies on reusing the
generated implementation class of that one base class.
No, but the limitation is summarized by the one sentence above. No
other caveats.
> take on that ?
It's a little like UML profiles for Ecore. I'm not familiar with all
the details.
>> create Ecore models on the fly and instantiate instances that conform
>> that that model, this too might be reinventing the wheel.
Yes, as long as that EObject's eClass() describes all there is to know
about that EObject. And that's how dynamic extension works, by taking
an existing implementation and ensure that eClass() returns the
extending EClass and ensuring that all generated implementation classes
support this dynamic extension (i.e., have correct dynamic delegation
for the reflective methods, i.e., for eGet, eSet, eIsSet, and eUnset.
> exists... ;)
Ed Merks
Current Time: Wed Apr 24 17:36:44 GMT 2024
Powered by FUDForum. Page generated in 0.03397 seconds
