Re: tool menu problem [message #200417 is a reply to message #200335] |
Tue, 05 August 2008 10:46 |
Originally posted by: tobk42.gmx.de
Hi Gary,
it seems that the displayed element name for the tools depend on what's
written in the plugin.properties file (not to be confused with the
plugin.xml). There should be a section #Providers holding the Names for
all the elements. In my case, there is an element with name "Undefined",
too, for which there is no tool (because it is the diagram root
element), so I would guess that your connections had no tool associated
with them when you first generated the code. On regenerating the code
the existing entry then has not been overwritten.
Well, just a guess... ^^;;
Tobias
Gary schrieb:
> Hi, I am currently working on a project where I have many connection's
> (links) so Inorder to make this project more user friendly I have mapped
> all these connections to a single tool!
> Now I am able to select this tool and when I draw a link a menu is
> displayed allowing me to select which type of link I wish to use (only
> the links which are appropriate to the nodes selected are shown).
> However there is a problem with this! The names of each of the links are
> not displayed!
> Each links is called currently:
> Create Undefined
> Does anyone know why this may be the case and how to get it to display
> the name of each of the links in the list?
> Thank you in advance,
> Gary J Burgin
FUDForum. Page generated in 0.02037 seconds
