Re: [Acceleo 3.4.x] How to import template / modul? [message #1231699 is a reply to message #1230326] |
Wed, 15 January 2014 08:19 |
Working with Acceleo 3.4.1 everyday in Kepler is fine for me.
By the way, your import seems to be correctly performed on your side. I don't understand why you have this error. Maybe a clean/re-build of your project may be sufficient I don't know.
Also, make sure that the name of your module corresponds to what you want to import. I mean that the 'DatabaseGeneratorHelper.mtl' file has the following header:
[comment encoding = UTF-8 /]
[module DatabaseGeneratorHelper('http://www.eclipse.org/xxxx/xxxx.0.0.1.xx')]
etc ...
Regards;
[Updated on: Wed, 15 January 2014 08:28] Report message to a moderator
Re: [Acceleo 3.4.x] How to import template / modul? [message #1234597 is a reply to message #1233921] |
Wed, 22 January 2014 10:34 |
Ralph Bergmann Messages: 10 Registered: July 2009 Location: Berlin / Germany |
I think I found the problem.
I created a Acceleo Project inside the "default location" and everything works fine.
But when I create the project inside a folder in the "dafault location" I get this error
!ENTRY org.eclipse.core.resources 4 2 2014-01-22 11:30:00.586
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.core.internal.resources.ResourceException: Resource '/eu.the4thfloor.dme.generator/bin/eu/the4thfloor/dme/generator/files/generate.emtl' does not exist.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:361)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.doBuild(AcceleoParser.java:627)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:431)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.buildImpactedModules(AcceleoParser.java:763)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.build(AcceleoParser.java:436)
at org.eclipse.acceleo.internal.parser.compiler.AcceleoParser.buildAll(AcceleoParser.java:262)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.buildAll(AcceleoBuilder.java:278)
at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:180)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:733)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource '/eu.the4thfloor.dme.generator/bin/eu/the4thfloor/dme/generator/files/generate.emtl' does not exist.
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:341)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:215)
at org.eclipse.core.internal.resources.File.getContents(File.java:287)
at org.eclipse.core.internal.resources.File.getContents(File.java:278)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl$WorkbenchHelper.createPlatformResourceInputStream(PlatformResourceURIHandlerImpl.java:207)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createInputStream(PlatformResourceURIHandlerImpl.java:525)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 21 more
!ENTRY org.eclipse.core.resources 4 75 2014-01-22 11:30:00.589
!MESSAGE Errors occurred during the build.
!SUBENTRY 1 org.eclipse.acceleo.ide.ui 4 75 2014-01-22 11:30:00.589
!MESSAGE Errors running builder 'Acceleo Builder' on project 'eu.the4thfloor.dme.generator'.
!STACK 0
... 21 more
!ENTRY org.eclipse.egit.core 4 0 2014-01-22 11:30:01.277
!MESSAGE Failed finding RepositoryMapping
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource '/eu.the4thfloor.dme.generator/tasks' is not local.
at org.eclipse.core.internal.resources.Resource.checkLocal(Resource.java:353)
at org.eclipse.core.internal.resources.Resource.checkAccessibleAndLocal(Resource.java:222)
at org.eclipse.core.internal.resources.Resource.getSessionProperty(Resource.java:1274)
at org.eclipse.egit.core.project.GitProjectData.getRepositoryMapping(GitProjectData.java:366)
at org.eclipse.egit.core.project.RepositoryMapping.getMapping(RepositoryMapping.java:271)
at org.eclipse.egit.ui.internal.decorators.GitLightweightDecorator.getIndexDiffDataOrNull(GitLightweightDecorator.java:206)
at org.eclipse.egit.ui.internal.decorators.GitLightweightDecorator.decorateResource(GitLightweightDecorator.java:180)
at org.eclipse.egit.ui.internal.decorators.GitLightweightDecorator.decorate(GitLightweightDecorator.java:166)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:263)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:365)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:371)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:331)
!SUBENTRY 1 org.eclipse.core.resources 4 369 2014-01-22 11:30:01.278
!MESSAGE Resource '/eu.the4thfloor.dme.generator/tasks' is not local.
!ENTRY org.eclipse.egit.core 4 0 2014-01-22 11:30:01.593
!STACK 1
!SUBENTRY 1 org.eclipse.core.resources 4 369 2014-01-22 11:30:01.594
!ENTRY org.eclipse.egit.core 4 0 2014-01-22 11:30:01.595
!STACK 1
!SUBENTRY 1 org.eclipse.core.resources 4 369 2014-01-22 11:30:01.595
!ENTRY org.eclipse.egit.core 4 0 2014-01-22 11:30:01.597
!STACK 1
!SUBENTRY 1 org.eclipse.core.resources 4 369 2014-01-22 11:30:01.597
[Updated on: Wed, 22 January 2014 10:38] Report message to a moderator
FUDForum. Page generated in 0.02965 seconds
