Can't execute test on AUT launched from Eclipse [message #1228990] |
Wed, 08 January 2014 13:48 |
I have a problem when I launch my RCP AUT from Eclipse. I've followed the help of jubula concerning "launch configurations" but I don't understand what's the source of my problem. So I will explain it :
I have created a test suite in Jubula which works fine on my AUT (from the .exe). Now I would like to execute my test suite from the source of my AUT in Eclipse.
For that, I've added the elements like it's specified in the help. I've added the needed plugin for rcp application and started it in the configuration.
I run my AUT from eclipse and in the "Functional Test Specification" I see my AUT in the "Running AUTs" view.
When I want to launch my test suite I have an error 7009: Test Execution Error with an error who says that my component can not be resolved. In the console view I see the error :
14:31:16.794 [Connection.ReaderThread:Socket[addr=MyPC,port=51758,localport=51920]] ERROR o.e.j.r.c.c.AbstractCapTestCommand - component 'org.eclipse.swt.custom.CTabFolder' is not supported: implementation class 'org.eclipse.jubula.rc.swt.implclasses.CTabFolderImplClass' not found
org.eclipse.jubula.rc.common.exception.UnsupportedComponentException: component 'org.eclipse.swt.custom.CTabFolder' is not supported: implementation class 'org.eclipse.jubula.rc.swt.implclasses.CTabFolderImplClass' not found
at org.eclipse.jubula.rc.common.AUTServerConfiguration.getImplementationClass(AUTServerConfiguration.java:269) ~[org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.AUTServerConfiguration.prepareImplementationClass(AUTServerConfiguration.java:347) ~[org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.commands.AbstractCapTestCommand.getImplClass(AbstractCapTestCommand.java:132) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.rc.common.commands.AbstractCapTestCommand.execute(AbstractCapTestCommand.java:226) [org.eclipse.jubula.rc.common.jar:na]
at org.eclipse.jubula.communication.Communicator$ConnectionListener.received(Communicator.java:844) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection.fireMessageReceived(Connection.java:401) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection.access$3(Connection.java:390) [org.eclipse.jubula.communication.jar:na]
at org.eclipse.jubula.communication.connection.Connection$ReaderThread.run(Connection.java:453) [org.eclipse.jubula.communication.jar:na]
I add a little information about my problem.
In fact, if I run my AUT via Jubula in my Eclipse installation (Juno)I have the same problem. I can't execute any test on my RCP application when I use the Jubula plugin.
Have you any idea to resolve my problem ?
Thanks for any help.
Elise Ruelle
ALL4TEC
[Updated on: Thu, 09 January 2014 09:08] Report message to a moderator
FUDForum. Page generated in 0.02729 seconds
