Exception while opening a non existing resource or resource from a closed project [message #1228984] |
Wed, 08 January 2014 13:33 |
sajja Phani Messages: 26 Registered: August 2011 |
I am getting the following exception while trying to open a non existing resource with API
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:344)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:3321)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1040)
at org.eclipse.ui.texteditor.StatusTextEditor.setFocus(StatusTextEditor.java:120)
at com.example.rcp.editor.CustomTextEditor.setFocus(OETextEditor.java:1251)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:192)
In earlier versions of eclipse it is working fine by opening a non editable editor with message 'Resource '.../ does not exists.'. This is especially occurring in 4.x, it is working as expected but logging the above specified exception.
What might cause this exception to be logged.
Thanks.
Sajja
FUDForum. Page generated in 0.02768 seconds
