Home » Modeling » TMF (Xtext) » Maven build using Nexus with P2 repositories(Problem with a Maven build using Nexus with P2 repositories)
Maven build using Nexus with P2 repositories [message #1228474] |
Tue, 07 January 2014 10:08  |
Adrian Pollak Messages: 27 Registered: August 2013 |
I use a Sonatype Nexus Repository with added P2 Repository Plugins.
https://docs.sonatype.org/display/Nexus/Nexus+OSGi+Experimental+Features+-+P2+Repository+Plugin
I have a valid maven build which creates all artifacts out of the mwe2 file
when I use the repositories (itemis.repository, p2.eclipse.kepler, fornax.plugin.repository) directly without Nexus.
Using Nexus leads to building errors with the "Fornax Model Workflow Maven2 Plugin V3.4.0"
because the Mwe2Launcher class, which is part of a P2 Repository, cannot be found.
The Fornax plugin libraries which are a maven2 repository are found during the build.
The Mwe2Launcher class is part of the "p2.eclipse.kepler" repository and cannot be found.
Does anybody have an idea why the P2 repositories are not accessible?
Any help is appreciated.
Regards Adrian
Picture Nexus:
The settings.xml configuration:
<mirrors>
<mirror>
<id>p2.eclipse.kepler</id>
<name>p2.eclipse.kepler</name>
<url>http://localhost:8081/nexus/content/repositories/p2.eclipse.kepler</url>
<layout>p2</layout>
<mirrorOfLayouts>p2</mirrorOfLayouts>
<mirrorOf>p2.eclipse.kepler</mirrorOf>
</mirror>
<mirror>
<id>fornax.plugin.repository</id>
<name>Fornax Plugin Repository</name>
<url>http://localhost:8081/nexus/content/repositories/fornax.plugin.repository</url>
<mirrorOf>fornax.plugin.repository</mirrorOf>
</mirror>
<mirror>
<id>nexus</id>
<name>nexus</name>
<url>http://localhost:8081/nexus/content/groups/public/</url>
<mirrorOf>*,!fornax.plugin.repository,!p2.eclipse.kepler</mirrorOf>
</mirror>
</mirrors>
<localRepository>C:\applications\maven-repository</localRepository>
Error when starting the maven build:
C:\workspaces\xtextMaven\myPackage>mvn -U install
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building DSL Definition (myPackage) 1.0.0-SNAPSHOT
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:add-source (add-source) @ myPackage ---
[INFO] Source directory: C:\workspaces\xtextMaven\myPackage\src-gen added.
[INFO] Source directory: C:\workspaces\xtextMaven\myPackage\src added.
[INFO] Source directory: C:\workspaces\xtextMaven\myPackage\xtend-gen added.
[INFO]
[INFO] --- fornax-oaw-m2-plugin:3.4.0:run-workflow (default) @ myPackage ---
[INFO] Fornax Model Workflow Maven2 Plugin V3.4.0
[INFO] pom.xml has been modified since last generator run at 20140106-14:53:14.
[INFO] Executing workflow in forked mode.
[INFO] java.lang.NoClassDefFoundError: org/eclipse/emf/mwe2/launch/runtime/Mwe2Launcher
[INFO] Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher
[ERROR] at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
[ERROR] at java.security.AccessController.doPrivileged(Native Method)
[ERROR] at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
[ERROR] at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
[ERROR] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
[ERROR] at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
[INFO] Could not find the main class: org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher. Program will exit.
[ERROR] ExitStatusException occurred while running workflow: Java returned: 1
[INFO] BUILD FAILURE
[INFO] Total time: 1.755s
[INFO] Finished at: Mon Jan 06 17:46:30 CET 2014
[INFO] Final Memory: 7M/110M
[ERROR] Failed to execute goal org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0:run-workflow (default) on project myPackage: Workflow
execution failed. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[Updated on: Tue, 07 January 2014 10:12] Report message to a moderator
Re: Maven build using Nexus with P2 repositories [message #1228513 is a reply to message #1228484] |
Tue, 07 January 2014 11:50   |
once again I have to thank you for the quick reply.
I have added the itemis repository which is necessary for the build but the first accessed P2 repository is the kepler one, so the error remains.
I added the "mvn -X install" log as file attachment.
Moreover I post the MANIFEST.MF content.
Nexus itemis repository:
Extended settings.xml:
<mirror>
<layout>p2</layout>
</mirror>
<mirror>
<id>itemis.repository</id>
<name>itemis.repository</name>
<url>http://localhost:8081/nexus/content/repositories/itemis.repository</url>
<layout>p2</layout>
<mirrorOf>itemis.repository</mirrorOf>
</mirror>
<mirror>
</mirror>
<mirror>
<id>nexus</id>
<name>nexus</name>
<mirrorOf>*,!fornax.plugin.repository,!p2.eclipse.kepler,!itemis.repository</mirrorOf>
</mirror>
The MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: com.pub.ba.dsl
Bundle-Vendor: My Company
Bundle-Version: 1.0.0.qualifier
Bundle-SymbolicName: com.pub.ba.dsl; singleton:=true
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.xtext;visibility:=reexport,
org.eclipse.xtext.xbase;resolution:=optional;visibility:=reexport,
org.eclipse.xtext.generator;resolution:=optional,
org.apache.commons.logging;bundle-version="1.0.4";resolution:=optional,
org.eclipse.emf.codegen.ecore;resolution:=optional,
org.eclipse.emf.mwe.utils;resolution:=optional,
org.eclipse.emf.mwe2.launch;resolution:=optional,
org.eclipse.xtext.util,
org.eclipse.emf.ecore,
org.eclipse.emf.common,
org.antlr.runtime,
org.eclipse.xtext.common.types
Import-Package: org.apache.log4j,
org.eclipse.xtext.xbase.lib
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: com.pub.ba.dsl,
com.pub.ba.dsl.services,
com.pub.ba.dsl.model,
com.pub.ba.dsl.model.impl,
com.pub.ba.dsl.model.util,
com.pub.ba.dsl.serializer,
com.pub.ba.dsl.parser.antlr,
com.pub.ba.dsl.parser.antlr.internal,
com.pub.ba.dsl.validation,
com.pub.ba.dsl.scoping,
com.pub.ba.dsl.generator,
com.pub.ba.dsl.formatting
[Updated on: Tue, 07 January 2014 12:00] Report message to a moderator
Re: Maven build using Nexus with P2 repositories [message #1228538 is a reply to message #1228513] |
Tue, 07 January 2014 13:10   |
Hmmm this looks very strange.
i have no idea what happens.
here is my output (using the repos directly)
as you can see all the eclipse stuff is there.
did you try to directly paste the nexus p2 urls into the projects
pom instead of using this mirror thingy?
[INFO] --- fornax-oaw-m2-plugin:3.4.0:run-workflow (default) @ org.xtext.example.mydsl ---
[DEBUG] Dependency collection stats: {ConflictMarker.analyzeTime=1, ConflictMarker.markTime=0, ConflictMarker.nodeCount=46, ConflictIdSorter.graphTime=0, ConflictIdSorter.topsortTime=0, ConflictIdSorter.conflictIdCount=24, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=3, ConflictResolver.conflictItemCount=46, DefaultDependencyCollector.collectTime=272, DefaultDependencyCollector.transformTime=5}
[DEBUG] org.fornax.toolsupport:fornax-oaw-m2-plugin:jar:3.4.0:
[DEBUG] org.apache.maven:maven-plugin-api:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-project:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-settings:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-profile:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-artifact-manager:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-repository-metadata:jar:2.1.0:compile
[DEBUG] backport-util-concurrent:backport-util-concurrent:jar:3.1:compile
[DEBUG] org.apache.maven:maven-plugin-registry:jar:2.1.0:compile
[DEBUG] org.codehaus.plexus:plexus-interpolation:jar:1.8.1:compile
[DEBUG] org.codehaus.plexus:plexus-container-default:jar:1.0-alpha-9-stable-1:compile
[DEBUG] junit:junit:jar:3.8.1:compile
[DEBUG] classworlds:classworlds:jar:1.1-alpha-2:compile
[DEBUG] org.apache.maven:maven-model:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-artifact:jar:2.1.0:compile
[DEBUG] org.apache.maven:maven-plugin-descriptor:jar:2.1.0:compile
[DEBUG] org.codehaus.plexus:plexus-utils:jar:1.5.12:compile
[DEBUG] com.google.inject:guice:jar:2.0:compile
[DEBUG] aopalliance:aopalliance:jar:1.0:compile
[DEBUG] org.apache.ant:ant:jar:1.8.3:compile
[DEBUG] org.apache.ant:ant-launcher:jar:1.8.3:compile
[DEBUG] commons-beanutils:commons-beanutils-core:jar:1.8.3:compile
[DEBUG] commons-logging:commons-logging:jar:1.1.1:compile
[DEBUG] commons-lang:commons-lang:jar:2.6:compile
[DEBUG] Created new class realm plugin>org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0
[DEBUG] Importing foreign packages into class realm plugin>org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0
[DEBUG] Imported: < project>org.xtext.example:org.xtext.example.mydsl:1.0.0-SNAPSHOT
[DEBUG] Populating class realm plugin>org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0
[DEBUG] Included: org.fornax.toolsupport:fornax-oaw-m2-plugin:jar:3.4.0
[DEBUG] Included: backport-util-concurrent:backport-util-concurrent:jar:3.1
[DEBUG] Included: org.codehaus.plexus:plexus-interpolation:jar:1.8.1
[DEBUG] Included: junit:junit:jar:3.8.1
[DEBUG] Included: org.codehaus.plexus:plexus-utils:jar:1.5.12
[DEBUG] Included: com.google.inject:guice:jar:2.0
[DEBUG] Included: aopalliance:aopalliance:jar:1.0
[DEBUG] Included: org.apache.ant:ant:jar:1.8.3
[DEBUG] Included: org.apache.ant:ant-launcher:jar:1.8.3
[DEBUG] Included: commons-beanutils:commons-beanutils-core:jar:1.8.3
[DEBUG] Included: commons-logging:commons-logging:jar:1.1.1
[DEBUG] Included: commons-lang:commons-lang:jar:2.6
[DEBUG] Excluded: org.apache.maven:maven-plugin-api:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-project:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-settings:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-profile:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-artifact-manager:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-repository-metadata:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-plugin-registry:jar:2.1.0
[DEBUG] Excluded: org.codehaus.plexus:plexus-container-default:jar:1.0-alpha-9-stable-1
[DEBUG] Excluded: classworlds:classworlds:jar:1.1-alpha-2
[DEBUG] Excluded: org.apache.maven:maven-model:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-artifact:jar:2.1.0
[DEBUG] Excluded: org.apache.maven:maven-plugin-descriptor:jar:2.1.0
[DEBUG] Configuring mojo org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0:run-workflow from plugin realm ClassRealm[plugin>org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0, parent: sun.misc.Launcher$AppClassLoader@1729854]
[DEBUG] Configuring mojo 'org.fornax.toolsupport:fornax-oaw-m2-plugin:3.4.0:run-workflow' with basic configurator -->
[DEBUG] (f) defaultOawResourceDir = oaw-generator
[DEBUG] (f) dependencies = [p2.eclipse-plugin:com.google.guava:jar:12.0.0.v201212092141:system, p2.eclipse-plugin:javax.inject:jar:1.0.0.v20091030:system, p2.eclipse-plugin:com.google.inject:jar:3.0.0.v201203062045:system, p2.eclipse-plugin:org.eclipse.osgi:jar:3.9.1.v20130814-1242:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-antlr.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-bcel.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-bsf.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-log4j.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-oro.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-regexp.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-resolver.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-apache-xalan2.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-commons-logging.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-commons-net.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-jai.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-javamail.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-jdepend.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-jmf.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-jsch.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-junit.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-junit4.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-launcher.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-netrexx.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-swing.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant-testutil.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.ant:jar:lib/ant.jar:1.8.4.v201303080030:system, p2.eclipse-plugin:org.apache.commons.lang:jar:2.6.0.v201205030909:system, p2.eclipse-plugin:org.apache.commons.logging:jar:1.1.1.v201101211721:system, p2.eclipse-plugin:org.apache.commons.cli:jar:1.2.0.v201105210650:system, p2.eclipse-plugin:org.eclipse.core.resources:jar:3.8.101.v20130717-0806:system, p2.eclipse-plugin:org.eclipse.core.runtime:jar:3.9.0.v20130326-1255:system, p2.eclipse-plugin:org.eclipse.core.expressions:jar:3.4.500.v20130515-1343:system, p2.eclipse-plugin:com.ibm.icu:jar:50.1.1.v201304230130:system, p2.eclipse-plugin:org.eclipse.core.commands:jar:3.6.100.v20130515-1857:system, p2.eclipse-plugin:org.eclipse.equinox.common:jar:3.6.200.v20130402-1505:system, p2.eclipse-plugin:org.eclipse.core.contenttype:jar:3.4.200.v20130326-1255:system, p2.eclipse-plugin:org.eclipse.equinox.preferences:jar:3.5.100.v20130422-1538:system, p2.eclipse-plugin:org.eclipse.equinox.registry:jar:3.5.301.v20130717-1549:system, p2.eclipse-plugin:org.eclipse.text:jar:3.5.300.v20130515-1451:system, p2.eclipse-plugin:org.eclipse.core.filesystem:jar:1.4.0.v20130514-1240:system, p2.eclipse-plugin:org.eclipse.core.jobs:jar:3.5.300.v20130429-1813:system, p2.eclipse-plugin:org.eclipse.equinox.app:jar:1.3.100.v20130327-1442:system, p2.eclipse-plugin:org.eclipse.core.variables:jar:3.2.700.v20130402-1741:system, p2.eclipse-plugin:org.eclipse.debug.core:jar:3.8.0.v20130514-0954:system, p2.eclipse-plugin:org.eclipse.emf.ecore:jar:2.9.1.v20130827-0309:system, p2.eclipse-plugin:org.eclipse.emf.ecore.xmi:jar:2.9.1.v20130827-0309:system, p2.eclipse-plugin:org.eclipse.emf.common:jar:2.9.1.v20130827-0309:system, p2.eclipse-plugin:org.eclipse.jdt.core:jar:3.9.1.v20130905-0837:system, p2.eclipse-plugin:org.eclipse.jdt.launching:jar:3.7.0.v20130515-1451:system, p2.eclipse-plugin:org.eclipse.emf.codegen:jar:2.9.0.v20131212-0558:system, p2.eclipse-plugin:org.eclipse.emf.codegen.ecore:jar:2.9.1.v20131212-0558:system, p2.eclipse-plugin:org.eclipse.emf.mwe2.runtime:jar:2.5.0.v201312110307:system, p2.eclipse-plugin:org.eclipse.emf.mwe.core:jar:1.2.1.v201312110307:system, p2.eclipse-plugin:org.eclipse.emf.mwe.utils:jar:1.3.1.v201312110307:system, p2.eclipse-plugin:org.eclipse.xtext.common.types:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtext.util:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.apache.log4j:jar:1.2.15.v201012070815:system, p2.eclipse-plugin:org.eclipse.xtext:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtext.generator:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.antlr.runtime:jar:3.2.0.v201101311130:system, p2.eclipse-plugin:org.eclipse.emf.mwe2.lib:jar:2.5.0.v201312110307:system, p2.eclipse-plugin:org.eclipse.emf.mwe2.language:jar:2.5.0.v201312110944:system, p2.eclipse-plugin:org.eclipse.emf.mwe2.launch:jar:2.5.0.v201312110944:system, p2.eclipse-plugin:org.eclipse.jdt.annotation:jar:1.1.0.v20130513-1648:system, p2.eclipse-plugin:org.eclipse.jdt.debug:jar:jdi.jar:3.8.0.v20130514-0841:system, p2.eclipse-plugin:org.eclipse.jdt.debug:jar:jdimodel.jar:3.8.0.v20130514-0841:system, p2.eclipse-plugin:org.eclipse.xtend:jar:1.4.0.v201306110406:system, p2.eclipse-plugin:org.eclipse.xpand:jar:1.4.0.v201306110406:system, p2.eclipse-plugin:org.eclipse.xtext.xbase.lib:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtend.lib:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtend.typesystem.emf:jar:1.4.0.v201306110406:system, p2.eclipse-plugin:org.eclipse.xtext.smap:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtext.ecore:jar:2.5.0.v201312110906:system, p2.eclipse-plugin:org.eclipse.xtext.xbase:jar:2.5.0.v201312110906:system]
[DEBUG] (f) outletResDir = src/generated/resources
[DEBUG] (f) outletResOnceDir = src/main/resources
[DEBUG] (f) outletResProtectedDir = src/protected/resources
[DEBUG] (f) outletResTestDir = src/test/generated/resources
[DEBUG] (f) outletResTestOnceDir = src/test/generated/java
[DEBUG] (f) outletResTestProtectedDir = src/test/protected/resources
[DEBUG] (f) outletSrcDir = src/generated/java
[DEBUG] (f) outletSrcOnceDir = /Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src
[DEBUG] (f) outletSrcProtectedDir = src/protected/java
[DEBUG] (f) outletSrcTestDir = src/test/generated/java
[DEBUG] (f) outletSrcTestOnceDir = /Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/java
[DEBUG] (f) outletSrcTestProtectedDir = src/test/protected/java
[DEBUG] (f) pluginArtifacts = [org.fornax.toolsupport:fornax-oaw-m2-plugin:maven-plugin:3.4.0:, backport-util-concurrent:backport-util-concurrent:jar:3.1:compile, org.codehaus.plexus:plexus-interpolation:jar:1.8.1:compile, junit:junit:jar:3.8.1:compile, org.codehaus.plexus:plexus-utils:jar:1.5.12:compile, com.google.inject:guice:jar:2.0:compile, aopalliance:aopalliance:jar:1.0:compile, org.apache.ant:ant:jar:1.8.3:compile, org.apache.ant:ant-launcher:jar:1.8.3:compile, commons-beanutils:commons-beanutils-core:jar:1.8.3:compile, commons-logging:commons-logging:jar:1.1.1:compile, commons-lang:commons-lang:jar:2.6:compile]
[DEBUG] (f) project = MavenProject: org.xtext.example:org.xtext.example.mydsl:1.0.0-SNAPSHOT @ /Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/pom.xml
[DEBUG] (f) timestampFileName = oaw-generation-lastrun.timestamp
[DEBUG] (f) workflowDescriptor = src/org/xtext/example/mydsl/GenerateMyDsl.mwe2
[DEBUG] (f) workflowEngine = mwe2
[DEBUG] -- end configuration --
[DEBUG] Added resource to classpath: file:/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src//
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.google.guava/12.0.0.v201212092141/com.google.guava-12.0.0.v201212092141.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/javax.inject/1.0.0.v20091030/javax.inject-1.0.0.v20091030.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.google.inject/3.0.0.v201203062045/com.google.inject-3.0.0.v201203062045.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.osgi/3.9.1.v20130814-1242/org.eclipse.osgi-3.9.1.v20130814-1242.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-antlr.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-bcel.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-bsf.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-log4j.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-oro.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-regexp.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-resolver.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-xalan2.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-commons-logging.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-commons-net.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jai.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-javamail.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jdepend.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jmf.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jsch.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-junit.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-junit4.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-launcher.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-netrexx.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-swing.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-testutil.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.lang/2.6.0.v201205030909/org.apache.commons.lang-2.6.0.v201205030909.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.logging/1.1.1.v201101211721/org.apache.commons.logging-1.1.1.v201101211721.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.cli/1.2.0.v201105210650/org.apache.commons.cli-1.2.0.v201105210650.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.resources/3.8.101.v20130717-0806/org.eclipse.core.resources-3.8.101.v20130717-0806.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.runtime/3.9.0.v20130326-1255/org.eclipse.core.runtime-3.9.0.v20130326-1255.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.expressions/3.4.500.v20130515-1343/org.eclipse.core.expressions-3.4.500.v20130515-1343.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.ibm.icu/50.1.1.v201304230130/com.ibm.icu-50.1.1.v201304230130.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.commands/3.6.100.v20130515-1857/org.eclipse.core.commands-3.6.100.v20130515-1857.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.common/3.6.200.v20130402-1505/org.eclipse.equinox.common-3.6.200.v20130402-1505.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.contenttype/3.4.200.v20130326-1255/org.eclipse.core.contenttype-3.4.200.v20130326-1255.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.preferences/3.5.100.v20130422-1538/org.eclipse.equinox.preferences-3.5.100.v20130422-1538.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.registry/3.5.301.v20130717-1549/org.eclipse.equinox.registry-3.5.301.v20130717-1549.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.text/3.5.300.v20130515-1451/org.eclipse.text-3.5.300.v20130515-1451.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.filesystem/1.4.0.v20130514-1240/org.eclipse.core.filesystem-1.4.0.v20130514-1240.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.jobs/3.5.300.v20130429-1813/org.eclipse.core.jobs-3.5.300.v20130429-1813.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.app/1.3.100.v20130327-1442/org.eclipse.equinox.app-1.3.100.v20130327-1442.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.variables/3.2.700.v20130402-1741/org.eclipse.core.variables-3.2.700.v20130402-1741.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.debug.core/3.8.0.v20130514-0954/org.eclipse.debug.core-3.8.0.v20130514-0954.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore/2.9.1.v20130827-0309/org.eclipse.emf.ecore-2.9.1.v20130827-0309.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore.xmi/2.9.1.v20130827-0309/org.eclipse.emf.ecore.xmi-2.9.1.v20130827-0309.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.common/2.9.1.v20130827-0309/org.eclipse.emf.common-2.9.1.v20130827-0309.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.core/3.9.1.v20130905-0837/org.eclipse.jdt.core-3.9.1.v20130905-0837.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.launching/3.7.0.v20130515-1451/org.eclipse.jdt.launching-3.7.0.v20130515-1451.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen/2.9.0.v20131212-0558/org.eclipse.emf.codegen-2.9.0.v20131212-0558.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen.ecore/2.9.1.v20131212-0558/org.eclipse.emf.codegen.ecore-2.9.1.v20131212-0558.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.runtime/2.5.0.v201312110307/org.eclipse.emf.mwe2.runtime-2.5.0.v201312110307.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.core/1.2.1.v201312110307/org.eclipse.emf.mwe.core-1.2.1.v201312110307.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.utils/1.3.1.v201312110307/org.eclipse.emf.mwe.utils-1.3.1.v201312110307.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.common.types/2.5.0.v201312110906/org.eclipse.xtext.common.types-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.util/2.5.0.v201312110906/org.eclipse.xtext.util-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.log4j/1.2.15.v201012070815/org.apache.log4j-1.2.15.v201012070815.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext/2.5.0.v201312110906/org.eclipse.xtext-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.generator/2.5.0.v201312110906/org.eclipse.xtext.generator-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.antlr.runtime/3.2.0.v201101311130/org.antlr.runtime-3.2.0.v201101311130.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.lib/2.5.0.v201312110307/org.eclipse.emf.mwe2.lib-2.5.0.v201312110307.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.language/2.5.0.v201312110944/org.eclipse.emf.mwe2.language-2.5.0.v201312110944.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.launch/2.5.0.v201312110944/org.eclipse.emf.mwe2.launch-2.5.0.v201312110944.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.annotation/1.1.0.v20130513-1648/org.eclipse.jdt.annotation-1.1.0.v20130513-1648.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.eclipse.jdt.debug-3.8.0.v20130514-0841.jar/jdi.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/.cache/tycho/org.eclipse.jdt.debug-3.8.0.v20130514-0841.jar/jdimodel.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend/1.4.0.v201306110406/org.eclipse.xtend-1.4.0.v201306110406.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xpand/1.4.0.v201306110406/org.eclipse.xpand-1.4.0.v201306110406.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase.lib/2.5.0.v201312110906/org.eclipse.xtext.xbase.lib-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.lib/2.5.0.v201312110906/org.eclipse.xtend.lib-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.typesystem.emf/1.4.0.v201306110406/org.eclipse.xtend.typesystem.emf-1.4.0.v201306110406.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.smap/2.5.0.v201312110906/org.eclipse.xtext.smap-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.ecore/2.5.0.v201312110906/org.eclipse.xtext.ecore-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase/2.5.0.v201312110906/org.eclipse.xtext.xbase-2.5.0.v201312110906.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/org/fornax/toolsupport/fornax-oaw-m2-plugin/3.4.0/fornax-oaw-m2-plugin-3.4.0.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/backport-util-concurrent/backport-util-concurrent/3.1/backport-util-concurrent-3.1.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/org/codehaus/plexus/plexus-interpolation/1.8.1/plexus-interpolation-1.8.1.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/junit/junit/3.8.1/junit-3.8.1.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/org/codehaus/plexus/plexus-utils/1.5.12/plexus-utils-1.5.12.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/com/google/inject/guice/2.0/guice-2.0.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/aopalliance/aopalliance/1.0/aopalliance-1.0.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/org/apache/ant/ant/1.8.3/ant-1.8.3.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/org/apache/ant/ant-launcher/1.8.3/ant-launcher-1.8.3.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/commons-beanutils/commons-beanutils-core/1.8.3/commons-beanutils-core-1.8.3.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar
[DEBUG] Added dependency to classpath: file:/Users/dietrich/.m2/repository/commons-lang/commons-lang/2.6/commons-lang-2.6.jar
[DEBUG] Setting fork to true for MWE2.
[DEBUG] /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java -classpath /Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.google.guava/12.0.0.v201212092141/com.google.guava-12.0.0.v201212092141.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/javax.inject/1.0.0.v20091030/javax.inject-1.0.0.v20091030.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.google.inject/3.0.0.v201203062045/com.google.inject-3.0.0.v201203062045.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.osgi/3.9.1.v20130814-1242/org.eclipse.osgi-3.9.1.v20130814-1242.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-antlr.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-bcel.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-bsf.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-log4j.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-oro.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-regexp.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-resolver.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-apache-xalan2.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-commons-logging.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-commons-net.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jai.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-javamail.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jdepend.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jmf.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-jsch.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-junit.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-junit4.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-launcher.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-netrexx.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-swing.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant-testutil.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.apache.ant-1.8.4.v201303080030.jar/lib/ant.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.lang/2.6.0.v201205030909/org.apache.commons.lang-2.6.0.v201205030909.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.logging/1.1.1.v201101211721/org.apache.commons.logging-1.1.1.v201101211721.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.commons.cli/1.2.0.v201105210650/org.apache.commons.cli-1.2.0.v201105210650.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.resources/3.8.101.v20130717-0806/org.eclipse.core.resources-3.8.101.v20130717-0806.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.runtime/3.9.0.v20130326-1255/org.eclipse.core.runtime-3.9.0.v20130326-1255.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.expressions/3.4.500.v20130515-1343/org.eclipse.core.expressions-3.4.500.v20130515-1343.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/com.ibm.icu/50.1.1.v201304230130/com.ibm.icu-50.1.1.v201304230130.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.commands/3.6.100.v20130515-1857/org.eclipse.core.commands-3.6.100.v20130515-1857.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.common/3.6.200.v20130402-1505/org.eclipse.equinox.common-3.6.200.v20130402-1505.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.contenttype/3.4.200.v20130326-1255/org.eclipse.core.contenttype-3.4.200.v20130326-1255.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.preferences/3.5.100.v20130422-1538/org.eclipse.equinox.preferences-3.5.100.v20130422-1538.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.registry/3.5.301.v20130717-1549/org.eclipse.equinox.registry-3.5.301.v20130717-1549.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.text/3.5.300.v20130515-1451/org.eclipse.text-3.5.300.v20130515-1451.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.filesystem/1.4.0.v20130514-1240/org.eclipse.core.filesystem-1.4.0.v20130514-1240.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.jobs/3.5.300.v20130429-1813/org.eclipse.core.jobs-3.5.300.v20130429-1813.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.app/1.3.100.v20130327-1442/org.eclipse.equinox.app-1.3.100.v20130327-1442.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.core.variables/3.2.700.v20130402-1741/org.eclipse.core.variables-3.2.700.v20130402-1741.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.debug.core/3.8.0.v20130514-0954/org.eclipse.debug.core-3.8.0.v20130514-0954.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore/2.9.1.v20130827-0309/org.eclipse.emf.ecore-2.9.1.v20130827-0309.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore.xmi/2.9.1.v20130827-0309/org.eclipse.emf.ecore.xmi-2.9.1.v20130827-0309.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.common/2.9.1.v20130827-0309/org.eclipse.emf.common-2.9.1.v20130827-0309.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.core/3.9.1.v20130905-0837/org.eclipse.jdt.core-3.9.1.v20130905-0837.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.launching/3.7.0.v20130515-1451/org.eclipse.jdt.launching-3.7.0.v20130515-1451.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen/2.9.0.v20131212-0558/org.eclipse.emf.codegen-2.9.0.v20131212-0558.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen.ecore/2.9.1.v20131212-0558/org.eclipse.emf.codegen.ecore-2.9.1.v20131212-0558.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.runtime/2.5.0.v201312110307/org.eclipse.emf.mwe2.runtime-2.5.0.v201312110307.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.core/1.2.1.v201312110307/org.eclipse.emf.mwe.core-1.2.1.v201312110307.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.utils/1.3.1.v201312110307/org.eclipse.emf.mwe.utils-1.3.1.v201312110307.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.common.types/2.5.0.v201312110906/org.eclipse.xtext.common.types-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.util/2.5.0.v201312110906/org.eclipse.xtext.util-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.apache.log4j/1.2.15.v201012070815/org.apache.log4j-1.2.15.v201012070815.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext/2.5.0.v201312110906/org.eclipse.xtext-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.generator/2.5.0.v201312110906/org.eclipse.xtext.generator-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.antlr.runtime/3.2.0.v201101311130/org.antlr.runtime-3.2.0.v201101311130.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.lib/2.5.0.v201312110307/org.eclipse.emf.mwe2.lib-2.5.0.v201312110307.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.language/2.5.0.v201312110944/org.eclipse.emf.mwe2.language-2.5.0.v201312110944.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.launch/2.5.0.v201312110944/org.eclipse.emf.mwe2.launch-2.5.0.v201312110944.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.jdt.annotation/1.1.0.v20130513-1648/org.eclipse.jdt.annotation-1.1.0.v20130513-1648.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.eclipse.jdt.debug-3.8.0.v20130514-0841.jar/jdi.jar:/Users/dietrich/.m2/repository/.cache/tycho/org.eclipse.jdt.debug-3.8.0.v20130514-0841.jar/jdimodel.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend/1.4.0.v201306110406/org.eclipse.xtend-1.4.0.v201306110406.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xpand/1.4.0.v201306110406/org.eclipse.xpand-1.4.0.v201306110406.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase.lib/2.5.0.v201312110906/org.eclipse.xtext.xbase.lib-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.lib/2.5.0.v201312110906/org.eclipse.xtend.lib-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.typesystem.emf/1.4.0.v201306110406/org.eclipse.xtend.typesystem.emf-1.4.0.v201306110406.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.smap/2.5.0.v201312110906/org.eclipse.xtext.smap-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.ecore/2.5.0.v201312110906/org.eclipse.xtext.ecore-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase/2.5.0.v201312110906/org.eclipse.xtext.xbase-2.5.0.v201312110906.jar:/Users/dietrich/.m2/repository/org/fornax/toolsupport/fornax-oaw-m2-plugin/3.4.0/fornax-oaw-m2-plugin-3.4.0.jar:/Users/dietrich/.m2/repository/backport-util-concurrent/backport-util-concurrent/3.1/backport-util-concurrent-3.1.jar:/Users/dietrich/.m2/repository/org/codehaus/plexus/plexus-interpolation/1.8.1/plexus-interpolation-1.8.1.jar:/Users/dietrich/.m2/repository/junit/junit/3.8.1/junit-3.8.1.jar:/Users/dietrich/.m2/repository/org/codehaus/plexus/plexus-utils/1.5.12/plexus-utils-1.5.12.jar:/Users/dietrich/.m2/repository/com/google/inject/guice/2.0/guice-2.0.jar:/Users/dietrich/.m2/repository/aopalliance/aopalliance/1.0/aopalliance-1.0.jar:/Users/dietrich/.m2/repository/org/apache/ant/ant/1.8.3/ant-1.8.3.jar:/Users/dietrich/.m2/repository/org/apache/ant/ant-launcher/1.8.3/ant-launcher-1.8.3.jar:/Users/dietrich/.m2/repository/commons-beanutils/commons-beanutils-core/1.8.3/commons-beanutils-core-1.8.3.jar:/Users/dietrich/.m2/repository/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar:/Users/dietrich/.m2/repository/commons-lang/commons-lang/2.6/commons-lang-2.6.jar org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher src/org/xtext/example/mydsl/GenerateMyDsl.mwe2 -p outlet.src.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/generated/java -p outlet.src.protected.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/protected/java -p outlet.res.test.protected.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/protected/resources -p outlet.res.once.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/main/resources -p basedir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl -p outlet.src.test.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/generated/java -p outlet.res.test.once.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/generated/java -p outlet.src.test.once.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/java -p outlet.src.test.protected.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/protected/java -p outlet.src.once.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src -p outlet.res.protected.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/protected/resources -p outlet.res.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/generated/resources -p outlet.res.test.dir=/Users/dietrich/xtext/xtext-maven-example/org.xtext.example.mydsl/src/test/generated/resources
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Maven build using Nexus with P2 repositories [message #1229063 is a reply to message #1228921] |
Wed, 08 January 2014 16:26  |
Hello Christian,
you finally hit the mark.
After referencing the nexus repositories directly and changing the mirror to "central" all necessary libraries are stored within the local repository "C:\applications\maven-repository".
At the end everything was build without an error.
As a resume there are two results I achieved within the final solution.
Both parts are done in one offline Maven build (Nexus OSS with p2 repositories required):
- Generate DSL Interpreter with Fornax plugins
- Use generated DSL Interpreter as a plugin to generate artifacts out of model files
Thank you very much for your help - once again!
Adrian
Final settings.xml:
<settings>
<mirrors>
<mirror>
<id>nexus</id>
<name>nexus</name>
<mirrorOf>central</mirrorOf>
</mirror>
</mirrors>
</settings>
Used repositories within the releng pom:
<repositories>
<repository>
<layout>p2</layout>
</repository>
<repository>
<layout>p2</layout>
</repository>
</repositories>
<pluginRepositories>
<pluginRepository>
</pluginRepository>
</pluginRepositories>
[Updated on: Wed, 08 January 2014 16:30] Report message to a moderator
Current Time: Thu Feb 25 20:35:12 GMT 2021
Powered by FUDForum. Page generated in 0.03048 seconds
