Re: [EMF Client Platform] create standalone product [message #1228868 is a reply to message #1228497] |
Wed, 08 January 2014 08:37 |
Jonas Helming Messages: 699 Registered: July 2009 |
Hi Chris,
OK, for this you need to define a "product definition" and export it.
As an example for a product definition, please refer to this bundle
org.eclipse.emf.ecp.products
,which contains the two product definitions of the demo applications for
ECP (for 3.x and e4)
I would recommend to reuse one of the existing products as a template.
You can start a product from within the IDE just like a run
configuration. Additionally you can export it from within the IDE or
using a build technology such as Maven Tycho.
Product files are actually not ECP specific, so you will find additional
documentation, google for "defining products eclipse"
Best Regards
Jonas
Am 07.01.2014 11:58, schrieb Chris Olden:
> Hi Jonas,
> I meant the latter. I want to export my application into a stand-alone
> product with exe-file (or linux-executable) to start.
> I want to create something like the "Demo Products" in the download
> section http://eclipse.org/ecp/download.html .
> Thanks for helping!
> Regards,
> Chris
> Jonas Helming wrote on Tue, 07 January 2014 03:40
>> Hi Chris,
>> do you want to define your oqn application, meaning do you want to
>> create your own design of a workbench? Or do you want to export your
>> running application into a stand-alone product (deployed as an .exe as
>> an example)?
>> Best Regards
>> Jonas
>> Am 06.01.2014 15:01, schrieb Chris Olden:
>> > Hello!
>> > > I have created a Project that uses the EMF Client Platform.
>> Everything
>> > works fine when i run is as an
>> > org.eclipse.emf.ecp.application.e3.application.
>> > But how can i finally create a standalone product that runs "without"
>> > eclipse. There are standalone demos on the ECP website which showed me
>> > that it is possible - and looked exactly like that what i want. I think
>> > exporting to RCP is the way for me but how do i actually do this?
>> > > Thanks!
Re: [EMF Client Platform] create standalone product [message #1229452 is a reply to message #1228974] |
Thu, 09 January 2014 13:25 |
the platform specific bundles are not in the configuration. They are
added during the export. You can build this with maven tycho and you
should get products for the different platforms then.
If you want to launch it, you need to add the platform specific parts to
the run configuration (try "add required").
Jonas
Am 08.01.2014 14:06, schrieb Chris Olden:
> Hi Jonas,
> now I have used the product configuration from here: github.com/eclipse/emf.ecp.other/blob/master/extra/org.eclipse.emf.ecp.application.e4/org.eclipse.emf.ecp.application.e4.product
> If I Launch my application with the button in the testing section of the product overview I get an error message (attached test.log), which says that org.eclipse.emf.ecp.application.e4.product could not be found.
> There are plug-ins missing in the dependency-tab, especially org.eclipse.emf.ecp.application.e4 and org.eclipse.emf.ecp.e4.application. The other missing ones are platform-dependant (carbon, cocoa, win32...).
> Where do I get the Ressources for org.eclipse.emf.ecp.e4.application or org.eclipse.emf.ecp.application.e4?
> Or do I have to change something else in my product configuration to make eclipse find my product? (see attached image for current configuration)
> I hope this helps you to help me :)
> If you need any more information - let me know.
> Regards,
> Chris
Re: [EMF Client Platform] create standalone product [message #1230679 is a reply to message #1229452] |
Sun, 12 January 2014 19:55 |
C O Messages: 4 Registered: January 2014 |
Maven tycho is another new chapter for me.
I will try this next week.
Thanks for your help so far.
I will be back in a few days making a new report.
Bests Regards,
Chris
Jonas Helming wrote on Thu, 09 January 2014 08:25Hi,
Jonas
> Hi Jonas,
> Regards,
> Chris
FUDForum. Page generated in 0.03728 seconds
