Eclipse WTP with Tomcat 6 to do ssi [message #199781] |
Sat, 15 September 2007 18:11 |
Originally posted by: fieseMoep.gmx.net
Hi folks,
i'm new to eclipse and wtp. After i have developed a number of projecs
in a rather minimalistic way with standalone editor, debugger, local
webserver and hand made versioning. I wanted to try eclipse as an
integrated solution...
So i installed the "get it all"-package from the WTP website:
wtp-all-in-one-sdk-R-2.0-200706260303-win32.zip
It's working fine no problem here to be found.
Next i setup a existing project for testing. The project is a simple
DHtml website with makes use of ssi. At the point to select a sufficient
server for testing and debugging i was unsure. As the server makes no
use of any advanced serversided technologies, i first tried the standard
web server served by the eclipse installation. The website was served by
the server and displayed in firefox, but the ssi were not served, the
sourcecode of the website in the browser shows that.
Next i setup the same project with the template for dynamic website. And
downloaded and installed both in eclipse and standalone Apache tomcat 6.
I configured the tomcat to recognise ssi derectives using the howto on
the apache website
(http://tomcat.apache.org/tomcat-6.0-doc/ssi-howto.html). AND added
after several hours of fruitless searching and trying the context.xml to
the server -config in eclipse.
In the End with the same behavior the website is served, but the ssi
were not recognised. I tried both servlet and filter setting for the
ssi. On startup the server throws no exeptions in the console window.
Changes i made to the tomcat config files.
web.xml
uncommented: the invoker servlet
in turns uncommented: ssi servlet or ssi filter and corresponding mappings
context.xml
changed <server> to <Context reloadable="true" privileged="true">
server.xml
change values maxThreads to "150" and port to "80"
Now i don't know want to do next. How to test this to get a feedback
want is wrong and not only that is not working...
Anyone got a hint?
Greets
Jens
For all with the same Problem of secrurity issues with servlets on
startup try this (mind that this is possibly unsecure, only for developing)
Add the context.xml found in the conf folder in the Tomcat installation
folder to the server -config found in Eclipse in Project
Explorer/Servers/Tomcat v6...
Than edit the contect.xml, change:
<server>
to
<server privileged="true">
Re: Eclipse WTP with Tomcat 6 to do ssi [message #199904 is a reply to message #199781] |
Mon, 17 September 2007 17:01 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I gave this a try with just the servlet. This amounted to:
1) Import the context.xml from the Tomcat 6.0.13 in to the "?-config"
directory under the Servers project in the workspace and add:
privileged="true"
to the <Context> element.
2) Uncomment the servlet declaration and mapping for the SSI servlet in
the web.xml in the "?-config" directory.
I was then able to create a simple test ".shtml" that used "#flastmod"
and it worked successfully.
If you remove the "privileged" attribute from the context.xml file, I
assume that the Tomcat server won't start due to a SecurityException.
If so, adding the "privileged" attribute back should complete enabling
of SSI. If it's not working at that point, there may be something else
that's going wrong. Your best bet may be to grab Tomcat source and try
to debug what's happening inside the SSI servlet or filter.
Larry
GmDerce76 wrote:
> Hi folks,
> the apache website
> web.xml
> context.xml
> server.xml
> Anyone got a hint?
> Greets
> Jens
> <server>
> to
Solved: Re: Eclipse WTP with Tomcat 6 to do ssi [message #199924 is a reply to message #199904] |
Mon, 17 September 2007 20:40 |
Thanks Larry,
that did it!
So everybody with the same problem try Larrys solution it works.
A Hint: Try it with a default installation of tomcat and a freshly
installed server runtime in Eclipse for unwanted behavior.
Greets
Jens
> privileged="true"
> assume that the Tomcat server won't start due to a SecurityException. If
> so, adding the "privileged" attribute back should complete enabling of
> Cheers,
> Larry
> GmDerce76 wrote:
>> Hi folks,
>> the apache website
>> web.xml
>> mappings
>> context.xml
>> server.xml
>> Anyone got a hint?
>> Greets
>> Jens
>> developing)
>> <server>
>> to
FUDForum. Page generated in 0.04051 seconds
