Home » Eclipse Projects » GEF » drawRoundedRectangle doesn't work with AnitAlias activated
drawRoundedRectangle doesn't work with AnitAlias activated [message #199771] Wed, 19 October 2005 09:23 Go to next message
Markus Brigl is currently offline Markus BriglFriend
Some methods on org.eclipse.draw2d.Graphics doesn't work on "Linux" if
antialising has been activated. I had the problem with
draw- & fillRoundedRectangle and with fillGradient.
I'm using cairo-0.1.23!
public class Snippet {
public static void main(String args[]) {
Display d = new Display();
final Shell shell = new Shell(d);
shell.setSize(400, 400);
LightweightSystem lws = new LightweightSystem(shell);
Figure contents = new Figure();
XYLayout contentsLayout = new XYLayout();
contents.setLayoutManager(contentsLayout);
Figure fig = new Figure() {
protected void paintClientArea(Graphics graphics) {
graphics.setForegroundColor(ColorConstants.black);
graphics.drawRoundRectangle(getBounds().shrink(1, 1), 50, 50);
// graphics.fillGradient(getBounds(), true);
public void paint(Graphics graphics) {
graphics.setAntialias(SWT.ON);
super.paint(graphics);
fig.setBounds(new Rectangle(100, 100, 100, 100));
contents.add(fig);
lws.setContents(contents);
shell.open();
while (!shell.isDisposed())
while (!d.readAndDispatch())
d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #199787 is a reply to message #199771] Wed, 19 October 2005 10:17 Go to previous messageGo to next message
Originally posted by: christian.sell.netcologne.de
could you elaborate what "doesnt work" means, for thos of us who dont
want to compile and run your code?
thanks,
christian
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #199811 is a reply to message #199771] Wed, 19 October 2005 15:04 Go to previous messageGo to next message
Originally posted by: none.unknown.com
You need Cairo 1.0 with Eclipse 3.2 integration builds. BTW, you shouldn't
be modifying the bounds directly as you do in the paintFigure() method.
Instead, do getBounds().getExpanded(-1,-1).
"Max" <mbrigl@gmx.net> wrote in message
news:pan.2005.10.19.09.23.46.601488@gmx.net...
> @Override
> @Override
> contents.add(fig);
> shell.open();
> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #199827 is a reply to message #199771] Wed, 19 October 2005 15:27 Go to previous messageGo to next message
Eclipse 3.1 required and shipped Cairo 0.4.
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200086 is a reply to message #199811] Thu, 20 October 2005 18:34 Go to previous messageGo to next message
Thank's it is working with cairo 1. It is possible to check if if
antialias (cairo) is available. In that way it would be possible to
activate antialias only if cairo has been installed.
regards
>> @Override
>> @Override
>> contents.add(fig);
>> shell.open();
>> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200094 is a reply to message #200086] Thu, 20 October 2005 16:43 Go to previous messageGo to next message
GC has a method setAdvanced() that you could manipulate to find out if
there's a
gc.setAdvanced(true);
boolean advancedGraphicsInstalled = gc.getAdvanced();
gc.setAdvanced(false);
These methods aren't reflected in the Graphics class yet, though.
news:pan.2005.10.20.18.34.33.844620@gmx.net...
> regards
shouldn't
> >> @Override
> >> @Override
> >> contents.add(fig);
> >> shell.open();
> >> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200109 is a reply to message #200094] Thu, 20 October 2005 19:17 Go to previous messageGo to next message
Hi Pratik,
how can I access the GC? The Graphic Context is hidden by SWTGraphics and
not accessible from outside.
> there's a
>> regards
> shouldn't
>> >> @Override
>> >> @Override
>> >> contents.add(fig);
>> >> shell.open();
>> >> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200170 is a reply to message #200109] Thu, 20 October 2005 21:08 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=103209
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101504
news:pan.2005.10.20.19.17.03.416219@gmx.net...
> Hi Pratik,
> > there's a
> >> regards
> > shouldn't
method.
if
> >> >> @Override
> >> >> @Override
> >> >> contents.add(fig);
> >> >> shell.open();
> >> >> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200178 is a reply to message #200170] Thu, 20 October 2005 21:11 Go to previous messageGo to next message
Until then, as a workaround, you can create your own GC.
"Pratik Shah" <none@unknown.com> wrote in message
news:dj910b$vs0$1@news.eclipse.org...
> > Hi Pratik,
and
> > > there's a
> > >> regards
> > > shouldn't
> method.
"Linux"
> if
> > >> >> @Override
> > >> >> @Override
> > >> >> contents.add(fig);
> > >> >> shell.open();
> > >> >> d.sleep();
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200186 is a reply to message #200178] Thu, 20 October 2005 22:14 Go to previous messageGo to next message
news:dj9162$c0$1@news.eclipse.org...
..... Using the display instead of a Control.
new GC(Display.getCurrent());
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200549 is a reply to message #200186] Tue, 25 October 2005 14:49 Go to previous messageGo to next message
With the latest release the problem doesn't appear anymore
Re: drawRoundedRectangle doesn't work with AnitAlias activated [message #200631 is a reply to message #200549] Tue, 25 October 2005 17:30 Go to previous message
Are you saying invoking setAntiAlias() fails gracefully if Cairo is not
installed?
news:pan.2005.10.25.14.34.01.321931@gmx.net...
Previous Topic:Move/Resize children only in parent boundaries.
Next Topic:Smooth Rendering (SVG or OpenGL)
Current Time: Wed Dec 11 16:16:32 GMT 2024
Powered by FUDForum. Page generated in 0.05121 seconds
