Home » Archived » Buckminster » is git.auto.fetch implemented at all?
is git.auto.fetch implemented at all? [message #1226792] Thu, 02 January 2014 18:21 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
Is git.auto.fetch considered during materialization?
I have it in my rmap, but if I materialize an eclipse workspace again
(using the same cloned repository) it never auto pulls changes (I saw
also this http://www.eclipse.org/forums/index.php/t/221619/ ). The same
holds if I remove the eclipse workspace and start the materialization again.
Indeed, by looking at
http://git.eclipse.org/c/buckminster/buckminster.git/tree/org.eclipse.buckminster.git/src/org/eclipse/buckminster/git/internal/RepositoryAccess.java
the property is stored in the field autoFetch but never used later...
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: is git.auto.fetch implemented at all? [message #1229407 is a reply to message #1226792] Thu, 09 January 2014 11:33 Go to previous messageGo to next message
anyone?
On 02/01/2014 19:21, Lorenzo Bettini wrote:
> Hi
> cheers
> Lorenzo
Xtext Book:
Re: is git.auto.fetch implemented at all? [message #1233781 is a reply to message #1226792] Mon, 20 January 2014 13:04 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
On 2014-01-02 19:21, Lorenzo Bettini wrote:
> Hi
Not really. That functionality was written as part of the first incarnation of the git support feature. I didn't know
enough about git to do a proper evaluation for a requirement spec. My current recommendation would be to not use it. If
someone has the time to look into how this should be implemented properly, then I'd be very interested in reviewing a
patch. One thing that comes to mind immediately is that the auto.fetch should be called auto.pull (since that's what it
was intended as).
- thomas
> cheers
> Lorenzo
Re: is git.auto.fetch implemented at all? [message #1236869 is a reply to message #1233781] Tue, 28 January 2014 09:06 Go to previous messageGo to next message
>> Hi
> incarnation of the git support feature. I didn't know enough about git
> recommendation would be to not use it. If someone has the time to look
> interested in reviewing a patch. One thing that comes to mind
> that's what it was intended as).
OK, I'll submit a bug and see whether I can come up with something :)
cheers
Lorenzo
Xtext Book:
Re: is git.auto.fetch implemented at all? [message #1438136 is a reply to message #1236869] Sun, 05 October 2014 15:16 Go to previous messageGo to next message
What is the status of this?
I appear to need to delete my Hudson Workspace to get a GIT 'refresh'.
Searching comes up with this correspondence.
On my Hudson HIPP I appear to have only the choice of Buckminster 4.2 so
perhaps 4.3 or 4.4 may have already fixed it.
But when I look at
https://projects.eclipse.org/projects/tools.buckminster/governance
I see that the current version of Buckminster is 2.0.0 perhaps released
18 months ago but if so without a release review. No plans for further
releases.
I'm really confused. What is the best Buckminster version and does it
fix the GIT refresh problem?
Ed Willink
>>> Hi
> cheers
> Lorenzo
Re: is git.auto.fetch implemented at all? [message #1462520 is a reply to message #1438136] Wed, 05 November 2014 17:13 Go to previous message
Ping. Anyone able to comment?
Ed Willink
On 05/10/2014 16:16, Ed Willink wrote:
> Hi
> But when I look at
> releases.
> Regards
> Ed Willink
>>>> Hi
>> cheers
>> Lorenzo
Previous Topic:java.lang.IllegalStateException: Preference node "file:" has been removed.
Next Topic:Trouble fetching a maven dependency
Current Time: Sun Jan 26 17:08:57 GMT 2020
Powered by FUDForum. Page generated in 0.01916 seconds
