Home » Eclipse Projects » GEF » fillGradient on a Figure
fillGradient on a Figure [message #199623] Mon, 17 October 2005 14:53 Go to next message
Originally posted by: prooteus_NOSPAM.gmx.net
I've got a Figure which contains a title bar and a content pane. The
content pane is of type 'RectangleFigure'. I would like to fill the
content pane with a gradient color.
Overriding the paintFigure(Graphics g) method did not succeed:
paintFigure(Graphics g) {
super.paintFigure(g);
g.fillGradient(this.getContentPane().getClientArea(), true);
Then I thought of overriding the method fillShape(Graphics g) of
RectangleFigure but that did not work either. The colors aren't changed
in any way.
Could someone please give me a hint.
Thanks in advance.
Stefan
Re: fillGradient on a Figure [message #199637 is a reply to message #199623] Mon, 17 October 2005 15:52 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Overriding fillShape() to invoke fillGradient(getBounds(), bool) should
work. Maybe you need to relaunch your application to see the change?
"Stefan Knieling" <prooteus_NOSPAM@gmx.net> wrote in message
news:dj0dsu$miv$1@news.eclipse.org...
> in any way.
> Thanks in advance.
> Stefan
Re: fillGradient on a Figure [message #199641 is a reply to message #199623] Mon, 17 October 2005 16:03 Go to previous messageGo to next message
You could switch to using a plain Figure for the content pane and it
wouldn't cover up your gradient.
Or...
> RectangleFigure but that did not work either. The colors aren't changed in
> any way.
Put a breakpoint to see if the method is called. Also, the foreground and BG
colors are important.
Re: fillGradient on a Figure [message #199649 is a reply to message #199641] Mon, 17 October 2005 16:42 Go to previous messageGo to next message
I've done so and overridden paintFigure(Graphics g). Now the gradient
works fine :-)
> and BG colors are important.
I put a breakpoint. The method fillShape(Graphics g) of RectangleFigure
was never called...
Thx a lot.
Re: fillGradient on a Figure [message #199653 is a reply to message #199649] Mon, 17 October 2005 20:57 Go to previous message
Perhaps the figure had no size and therefore didn't paint?? fill is set to
true by default in Shape.
news:dj0k8u$vni$1@news.eclipse.org...
> works fine :-)
> was never called...
> Thx a lot.
Previous Topic:Filtering out nodes and connections from a diagram results in dangling connections in filtered state
Next Topic:Outline with a Tree
Current Time: Sat Dec 07 21:13:45 GMT 2024
Powered by FUDForum. Page generated in 0.03814 seconds
