Home » Language IDEs » ServerTools (WTP) » Setting the default value of an element in the xsd schema editor
Setting the default value of an element in the xsd schema editor [message #199617] Tue, 11 September 2007 15:02 Go to next message
Robert Gruendler is currently offline Robert GruendlerFriend
maybe this seems very obvious, but i can't find a way to set the default
values in the schema editor.
thanks!
-robert
Re: Setting the default value of an element in the xsd schema editor [message #199719 is a reply to message #199617] Fri, 14 September 2007 01:25 Go to previous message
Craig Salter is currently offline Craig SalterFriend
I can see why you can't find it... coz it looks like it's not there in the
properties sheet. You'll need to hop over to the source view and add it
there (use CTRL-SPACE) for content assist.
It's probably absent from the UI since this feature of XML schema doesn't
get used very often. Feel free to open a bug to request that this gets
added to the property sheet for <element> and <attribute> objects.
Robert Gruendler wrote:
> thanks!
> -robert
Previous Topic:Run on server for jsp
Next Topic:Error while creating Dynamic Web Project
Current Time: Thu Nov 26 13:21:36 GMT 2020
Powered by FUDForum. Page generated in 0.04669 seconds
