ATL dynamic creation and referencing [message #1226482] |
Wed, 01 January 2014 22:31 |
Chris Bailey Messages: 11 Registered: January 2014 |
Hi all,
I'm very new to ATL, i've read through the user guide and completed a few exercises. I was pointed to ATL as I was told it may be a suitable solution to a problem.
I have a model in xmi that needs to be transformed into a UML model with a bespoke profile. A tool exists for the UML model that can validate the model which I need to use. Both represent implementations of the Role Based Access Control model.
I'm trying to find out if it is possible to dynamically create packagedElements that can exist in a uml:Model.
For example, the structure of the output needs to look like this (as required by the validation tool):
<xmi>
<uml:Model>
<packagedElement xmi:type="uml:Class" xmi:id="_G9m0MKsoEeKCpaBuCpEQoA" name="Doe ">
<ownedAttribute xmi:id="_j4LtIKsoEeKCpaBuCpEQoA" name="student" type="_a1bTMKsoEeKCpaBuCpEQoA"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_a1bTMKsoEeKCpaBuCpEQoA" name="Student ">
<ownedAttribute xmi:id="_j4YhcKsoEeKCpaBuCpEQoA" name="doe" type="_G9m0MKsoEeKCpaBuCpEQoA"/>
</packagedElement>
</uml:Model>
<rbacDSML:User xmi:id="_G_lKIKsoEeKCpaBuCpEQoA" base_Class="_G9m0MKsoEeKCpaBuCpEQoA"/>
<rbacDSML:rbacRole xmi:id="_a1gLsKsoEeKCpaBuCpEQoA" base_Class="_a1bTMKsoEeKCpaBuCpEQoA"/>
</xmi>
Essentially, I have to create several uml class references in the model. Notice that the xmi:id of 'Doe' matches the type of the ownedAttribute in Student. In addition, the rbacDSML elements need to be created and reference packagedElements in the uml:Model. So for 'Doe' it references as a rbacDSML:User (check base_Class).
Question: If I have a list of roles and users in my input model, can I dynamically create these packagedElements using ATL, embed them into a created <uml:Model>, and be able to reference created packagedElements (or update existing ones)? I've been able to do part of it statically, but I need to be able to do it dynamically.
My first attempt at the rules (the static route):
rule policy562rbacDSML {
from
s: policy56!X509PMIRBACPolicy
to
m: UML!Model(
name <- thisModule.policyIdType,
packagedElement <- OrderedSet {r1},
packagedElement <- OrderedSet {r2}
r1: UML!Class(
name <- thisModule.roles.get(0)
r2: UML!Class(
name <- thisModule.roles.get(1)
rd1: rbacDSML!rbacRole(
base_Class <- r1
rd2: rbacDSML!rbacRole(
base_Class <- r2
This creates two separate model files, but creates my packagedElements within uml:Model (which I want), but no idea how to get the rbacDSML elements to appear below the <uml:Model/> element, and to be created dynamically. The required output structure to me doesn't seem proper, but I could be wrong, i'm new to this .
The other way I've tried to do this is with these types of rules:
--Create uml:Model
rule policy562umlModel{
from
to
m: UML!Model(
--Create rbac roles from p56roles
rule p56role2rbac {
from
s: policy56!SupRole
to
r: UML!Class(
name <- s.Value
rd: rbacDSML!rbacRole(
base_Class <- r
This dynamically creates all the role elements in the output model for me, but not as packagedElements, and I'm not sure how I could package this into the uml:Model.
Look forward to any help/advice/links to documentation that could help me out. If someone is able to tell me what I'm trying to achieve is not possible (or is), then even better!
Many thanks!
Re: ATL dynamic creation and referencing [message #1227029 is a reply to message #1227026] |
Fri, 03 January 2014 10:37 |
In order for the UML Model to contain the Class instances, you'll need to assign a value to Model::packagedElement like you did in the static example. ATL provides the implicit tracing mechanism, which automatically replaces source values by target values in a '<-' binding. Something like this:
from
to
m: UML!Model(
packagedElement <- s.supRoles
...where s.supRoles would be a collection of policy56!SupRole, which are then replaced by the implicit tracing mechanism by the UML Class instances created in the p56role2rbac rule.
Dennis
[Updated on: Fri, 03 January 2014 10:38] Report message to a moderator
Re: ATL dynamic creation and referencing [message #1228942 is a reply to message #1227500] |
Wed, 08 January 2014 11:47 |
For folks interested in the solution (probably more relevant for those new to the language, like myself):
To create a UML model with an applied UML profile.
OUT uses a UML metamodel
IN takes my own ecore model I want to transform from
PRO takes the UML profile as input, but uses the same UML metamodel.
In your launch configuration you should have 2 metamodels (the UML and your input metamodel), 2 inputs (the model conforming to your input metamodel, and the uml profile).
I create the model and use t.applyProfile() to apply the uml profile. To use stereotypes that exist in my profile I use t.applyStereotypes().
create OUT: UML from IN: saafABAC, PRO : UML ;
----HELPER Methods
--Get Stereotype that matches String
helper def: getStereotype(s : String) : UML!Stereotype =
UML!Stereotype.allInstancesFrom('PRO')->select(e | e.name = s)->first();
----TRANSFORMATION Rules
rule createModel {
from
s: saafABAC!AbacModel
to
t: UML!Model(
name <- 'rbacDSMLmodel',
packagedElement <- saafABAC!Subject.allInstancesFrom('IN')
->collect(e | thisModule.createSubjects(e))
do{
t.applyProfile(UML!Profile.allInstancesFrom('PRO')->select(p | p.name = 'rbacDSML')->first());
lazy rule createSubjects{
from
s: saafABAC!Subject
to
t: UML!Class(
name <- s.ID
do{
t.applyStereotype(thisModule.getStereotype('User'));
FUDForum. Page generated in 0.04319 seconds
