Multiple Deletes Issue [message #199366] |
Tue, 29 July 2008 12:28 |
Originally posted by: awm_abu.yahoo.com
Hello all,
I want to show the user a dialog which allows them to cancel a delete when
deleting objects from a GMF diagram.
I return a command from the EdtiAdviceHelper.getBeforeDestroyElementCommand
This command asks the user if they want to continue and then either cancels
or runs.
My issue is when I try to delete multiple objects at once.
The getBeforeDestoryElementCommand is called for each element so I end up
with a dialog for each element that is going to be deleted.
What I am wondering is how can I group the elements to be deleted together
and show all in one dialog ?
thanks a lot,
Alan.
Re: Multiple Deletes Issue [message #199417 is a reply to message #199366] |
Tue, 29 July 2008 17:44 |
Originally posted by: cdamus.zeligsoft.com
Hi, Alan,
You can take advantage of the fact that the edit-helper constructs its
edit command in the context of a read-only transaction. You can use the
InternalTransactionalEditingDomain::getActiveTransaction() API to get
the current transaction and, in a map of some kind, cache your prompting
command with the transaction as the key.
Subsequent invocations of your advice can find the cached prompt command
and append elements to it instead of returning new advice commands.
Just be sure to purge the transaction from the cache when your prompting
command is dispose()d.
HTH,
Christian
Alan wrote:
> Hello all,
> or runs.
> thanks a lot,
> Alan.
FUDForum. Page generated in 0.02974 seconds
