Home » Eclipse Projects » GEF » Example projects in CVS don't compile with GEF 3.1.1
Example projects in CVS don't compile with GEF 3.1.1 [message #199067] Thu, 13 October 2005 18:06 Go to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
I noticed that most of the example projects in CVS don't compile when used
with GEF 3.1.1. It seems like some abstract methods are not implemented.
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199080 is a reply to message #199067] Thu, 13 October 2005 18:08 Go to previous messageGo to next message
That is correct.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dim7mo$o9u$1@news.eclipse.org...
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199088 is a reply to message #199067] Thu, 13 October 2005 18:10 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Yes, those abstract methods were made concrete in 3.2. Empty
implementations of such methods were removed from sub-classes.
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199144 is a reply to message #199088] Thu, 13 October 2005 20:56 Go to previous messageGo to next message
So it there a CVS tag I can extract to have it compile with 3.1.1?
"Pratik Shah" <none@unknown.com> wrote in message
news:dim7u7$olb$1@news.eclipse.org...
>> used
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199181 is a reply to message #199144] Thu, 13 October 2005 22:37 Go to previous messageGo to next message
R31_Maintenance
news:dimhms$6bv$1@news.eclipse.org...
> >> used
implemented.
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199277 is a reply to message #199181] Fri, 14 October 2005 14:12 Go to previous messageGo to next message
That tag and and R3_1 both produce this error in ediagram:
The type DiagramLayoutEditPolicy must implement the inherited abstract
method ConstrainedLayoutEditPolicy.createAddCommand(EditPart, Object)
in
org.eclipse.gef.examples.ediagram/src/org/eclipse/gef/exampl es/ediagram/edit/policies/DiagramLayoutEditPolicy.java
line 57
news:dimnk8$d6m$1@news.eclipse.org...
> R31_Maintenance
>> >> used
> implemented.
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199286 is a reply to message #199277] Fri, 14 October 2005 14:18 Go to previous messageGo to next message
Actually, with the R3_1 tag the error goes away.
news:dioec0$bm1$1@news.eclipse.org...
> in
> line 57
>> R31_Maintenance
>>> >> used
>> implemented.
Re: Example projects in CVS don't compile with GEF 3.1.1 [message #199310 is a reply to message #199144] Fri, 14 October 2005 14:36 Go to previous message
Mixing CVS streams is the same as mixing releases. The 3.1 release of the
examples would not compile with GEF 3.0.
HEAD is ongoing 3.2 work, and the HEAD examples will require all of the
other GEF plug-ins from HEAD, as well as whichever level of the eclipse
platform we decide to use that day, which is typically the most recent 3.2
milestone.
>>> used
Previous Topic:How to remove the selection box when the figure is hidden?
Next Topic:thanx for GEF and Draw2d Developer's Guide in 3.1.1 doc
Current Time: Thu Dec 05 10:25:16 GMT 2024
Powered by FUDForum. Page generated in 0.05228 seconds
