[Acceleo] Testing an acceleo project, which depends on another acceleo project [message #1224493] |
Thu, 26 December 2013 22:57 |
Joe I Messages: 28 Registered: May 2013 |
Hello!
In my case, I have an "utility" acceleo project, which contains queries, I would like to use for several acceleo generators.
So what I do is, I add the utility project to the dependencies of a generator project. It works fine, when I try the generator in eclipse.
But when I try to test the generator with junit, it seems that acceleo cannot find the utility queries. Without the utility queries, I can test the generator and acceleo doesn't complain.
Thanks for help!
Error messages:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Unresolved compilation error in generation module.
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1808)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:1042)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVisitor.java:872)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1864)
at org.eclipse.acceleo.model.mtl.impl.spec.QueryInvocationSpec.accept(QueryInvocationSpec.java:49)
at org.eclipse.ocl.AbstractEvaluationVisitor.safeVisitExpression(AbstractEvaluationVisitor.java:575)
at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:222)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.java:1226)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(OperationCallExpImpl.java:390)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:248)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(EvaluationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1887)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.java:571)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1825)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.java:914)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1819)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(QueryImpl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:365)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:142)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerateTemplate(AcceleoService.java:884)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:585)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:194)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:159)
at dsl.pim.poe.gen.xml.main.Generate.doGenerate(Generate.java:203)
at dsl.pim.poe.gen.xml.tests.TestUtil.generateUmlToXml(TestUtil.java:91)
at dsl.pim.poe.gen.xml.tests.XmlGeneratorTest.test(XmlGeneratorTest.java:32)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
org.eclipse.acceleo.engine.AcceleoEvaluationException: Undefined condition of "If" at line 8 in Module generate for block if (unresolved query invocation : null().and(aClass.name.equalsIgnoreCase('Context'))). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.InteractionImpl@6ea3ffa8 (name: case(): Verdict, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false) (isReentrant: <unset>).
at generate.generateXML(Class)(generate.mtl:8)
at generate.generateXML(Class)(generate.mtl:6)
org.eclipse.acceleo.engine.AcceleoEvaluationException: Undefined condition of "If" at line 8 in Module generate for block if (unresolved query invocation : null().and(aClass.name.equalsIgnoreCase('Context'))). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.ClassImpl@56946d74 (name: Context, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false).
Re: [Acceleo] Testing an acceleo project, which depends on another acceleo project [message #1224984 is a reply to message #1224493] |
Sat, 28 December 2013 10:16 |
Ed Willink Messages: 7655 Registered: July 2009 |
Some suggestions based on past experience.
Use ASCII rather than binary encoding of your emtl files, so that you
can read them. You also get a different URI resolution for ASCII files.
Make sure you do a couple of cleans and rebuilds and restarts after
changing settings. Make sure you really have no compilation errors.
Sometimes a dummy edit in an included file is necessary to force a
correctly sequenced rebuild.
See if the ../../..'s in the *.emtl files are sensible.
See if the Sample Ecore Editor thinks they are sensible.
Acceleo has some pragmatic heuristics to allow ../.. determined within
Eclipse as platform:-relative to be re-used standalone as
file:-relative. IMHO these heuristics make life worse for an advanced
user (like you). So you may want to ensure that the relative placement
of your projects is in a place where Acceleo's heuristics don't go wrong.
Alternatively, you may find that you need to intercept the Acceleo
initialization to correct URI references for standalone usage.
If still stuck, try other versions of Acceleo. If you scan my previous
postings you will find some recommendations about versions that did and
didn't work for me. However time has passed and I have migrated my
templates to Xtend so observations on good/bad versions may be obsolete.
Ed Willink
On 26/12/2013 22:57, Joe I wrote:
> Hello!
> Thanks for help!
> Error messages:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.02999 seconds
