Re: Problems with the source code - need help! [message #1226537 is a reply to message #1224653] |
Thu, 02 January 2014 02:21 |
Hi Markus,
glad you decided to checkout Stardust. You may have seen that we have two modelers. The Eclipse-based and the bowser-based. Which one do you intend to modify?
Eclipse-based: Here I guess your current issue boils down to the question what the development lifecycle will be. I would recommend to go through an eclipse-plugin development tutorial first, so you know how to run an 'Eclipse with your modified plugins' from within your Eclipse IDE.
Browser-based: The browser-based modeler is closer to BPMN2 and supports the serialization. It is mostly Java script. This may be the easier entry point for your objective.
If you have specific questions then we can certainly help.
Best regards
Rob
FUDForum. Page generated in 0.02583 seconds
