Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1226979 is a reply to message #1223430] |
Fri, 03 January 2014 07:59 |
Hi Leonid,
I also experience this problem recently and I was about to commit a simple fix for it. But then I looked at
CDOLazyContentAdapter a little bit longer and thought it should be reimplemented from scratch without extending
EContentAdapter. If you want me to fix the ConcurrentModificationException separately, please submit a bugzilla and I'll
look at it.
Cheers
/Eike
http://www.esc-net.de
Am 23.12.2013 12:04, schrieb Leonid Ripeynih:
> When trying to use graphiti with CDO (4.2.0) i've run into a following problem: calling setTrackingModification(true)
> on diagram resource immediately results in java.util.ConcurrentModificationException.
> Here is the stack trace:
> at java.util.HashMap$HashIterator.nextEntry(HashMap.java:793)
> at java.util.HashMap$EntryIterator.next(HashMap.java:834)
> at java.util.HashMap$EntryIterator.next(HashMap.java:832)
> at org.eclipse.net4j.util.ref.ReferenceValueMap2$EntrySetIterator.hasNext(ReferenceValueMap2.java:408)
> at java.util.AbstractMap$2$1.hasNext(AbstractMap.java:356)
> at java.util.Collections$UnmodifiableCollection$1.hasNext(Collections.java:1007)
> at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.addCleanObjectHandler(CDOLazyContentAdapter.java:123)
> at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.setTarget(CDOLazyContentAdapter.java:61)
> at org.eclipse.emf.ecore.util.EContentAdapter.setTarget(EContentAdapter.java:182)
> at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:489)
> at org.eclipse.emf.ecore.impl.MinimalEObjectImpl$1ArrayDelegatingAdapterList.didAdd(MinimalEObjectImpl.java:1)
> at org.eclipse.emf.common.util.ArrayDelegatingEList.addUnique(ArrayDelegatingEList.java:389)
> at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
> at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.setTrackingModification(CDOResourceImpl.java:499)
> Is there anything im doing wrong?
Cheers
/Eike
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1227372 is a reply to message #1227050] |
Sat, 04 January 2014 09:32 |
Am 03.01.2014 12:43, schrieb Christophe Bouhier:
> On 03-01-14 08:59, Eike Stepper wrote:
>> Hi Leonid,
>> simple fix for it. But then I looked at CDOLazyContentAdapter a little
>> extending EContentAdapter. If you want me to fix the
> Yes this is a known issue with the CDOLazyContentAdapter.
> I reported this bug here:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=399723
That bug is more like an umbrella bug. I've now fixed the ConcurrentModificationException via:
424889: ConcurrentModificationException in CDOLazyContentAdapter
https://bugs.eclipse.org/bugs/show_bug.cgi?id=424889
Cheers
/Eike
> I spend quiet some time using the CDOLazyContentAdapter and trying
> to change it so it can deal with anything else than a Resource as a root. My conclusion, it's very broken..and indeed
> needs to be redone.
> The root cause of the concurrentmod, is that walking an object (For example to check containment, will trigger objects
> to be loaded, which will update the ObjectHandler and fire concurrentmod exception.
>> I'll look at it.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>>> problem: calling setTrackingModification(true) on diagram resource
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Cheers
/Eike
Re: [EMF] [CDO] ConcurrentModificationException when setting setTrackingModification(true) [message #1242235 is a reply to message #1230955] |
Sun, 09 February 2014 07:35 |
Am 13.01.2014 13:57, schrieb Leonid Ripeynih:
> Eike, after applying the fix, error has changed to:
> java.lang.IllegalStateException: Different object was registered for OID3693
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerObject(AbstractCDOView.java:1324)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:923)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1150)
> at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1255)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:702)
> at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.getContainer(CDOStoreImpl.java:129)
> at org.eclipse.emf.internal.cdo.CDOObjectImpl.eInternalContainer(CDOObjectImpl.java:707)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eInternalResource(BasicEObjectImpl.java:929)
> at org.eclipse.emf.internal.cdo.CDOObjectImpl.eInternalResource(CDOObjectImpl.java:581)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResource(BasicEObjectImpl.java:920)
> at org.eclipse.emf.internal.cdo.CDOObjectImpl.cdoResource(CDOObjectImpl.java:166)
> at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.isContained(CDOLazyContentAdapter.java:208)
> at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.addCleanObjectHandler(CDOLazyContentAdapter.java:124)
> at org.eclipse.emf.cdo.util.CDOLazyContentAdapter.setTarget(CDOLazyContentAdapter.java:60)
I've added this stacktrace to https://bugs.eclipse.org/bugs/show_bug.cgi?id=424889
Cheers
/Eike
Cheers
/Eike
FUDForum. Page generated in 0.03293 seconds
