Re: EMF code generator [Error emf.Ecore2Java] [message #1223468 is a reply to message #1223440] |
Mon, 23 December 2013 13:30 |
Ed Merks Messages: 33141 Registered: July 2009 |
I'm not an expert on how to invoke ant tasks programatically so I can't
answer that and I'm not sure it's even possible or sensible.
On 23/12/2013 12:45 PM, javs javs wrote:
> friend you did not understand, how could I fix this?
> many thanks
> Ed Merks wrote on Mon, 23 December 2013 02:01
>> If you're trying to run the generator as a action in the IDE, you'd
>> be better to look at what the ant task does and do that directly in
>> your action. I don't know how you're supposed to invoke an ant task
>> programatically. You can also configure any project to automatically
>> run ant tasks during a build without needing your own specialized
>> action.
>> On 23/12/2013 4:45 AM, javs javs wrote:
>> > hello friends,
>> > I'm trying to run an ant task that contains a target of
>> emf.Ecore2Java, I try to run it from java but I get the following error:
>> > Problem: failed to create task or type emf.Ecore2Java
>> > pictures in this more specific
> many thanks
>> action.
>> > hello friends,
Ed Merks
FUDForum. Page generated in 0.03360 seconds
