Home » Eclipse Projects » GEF » Connections stop one pixel short of node
Connections stop one pixel short of node [message #198714] Wed, 12 October 2005 16:44 Go to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
Since release 3.1, I have seen a strange anomaly in my diagrams: connections
that touch my node on the top or left side stop one pixel short of the node
itself. This does not happen if there is a decoration on that connection end
or if the connection has a very shallow angle to the node. What could be the
cause of this?
Re: Connections stop one pixel short of node [message #198755 is a reply to message #198714] Wed, 12 October 2005 17:14 Go to previous messageGo to next message
Does this happen at the source/origin of the connection, or only at the
target end?
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:dijei3$8i1$1@news.eclipse.org...
> connections that touch my node on the top or left side stop one pixel
> short of the node itself. This does not happen if there is a decoration on
> that connection end or if the connection has a very shallow angle to the
> node. What could be the cause of this?
Re: Connections stop one pixel short of node [message #198794 is a reply to message #198755] Wed, 12 October 2005 17:28 Go to previous messageGo to next message
It does happen at the source of the connection, but I cannot immediately day
if it happens at the target also because at the target there is usually a
decoration. Also I saw that one connection which did not have any decoration
did touch the source and target nodes properly without the 1-pixel gap. And
once the angle between the top of the node and the connection becomes 45
degrees or less, the gap vanishes also.
Do you need me to look for the target end specifically?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dijg9e$as1$1@news.eclipse.org...
> target end?
>> on that connection end or if the connection has a very shallow angle to
>> the node. What could be the cause of this?
Re: Connections stop one pixel short of node [message #198809 is a reply to message #198794] Wed, 12 October 2005 17:35 Go to previous messageGo to next message
On win32, we used to paint an extra dot at the end of the connection. This
was done in SWTGraphics#drawPolyline(PointList).
SWT fixed this inconsistency and we removed our workaround.
You should try reproducing in the logic example, and/or post a snippet
showing the problem.
news:dijh3p$btd$1@news.eclipse.org...
> day if it happens at the target also because at the target there is
> usually a decoration. Also I saw that one connection which did not have
> any decoration did touch the source and target nodes properly without the
> 1-pixel gap. And once the angle between the top of the node and the
> connection becomes 45 degrees or less, the gap vanishes also.
>> target end?
Re: Connections stop one pixel short of node [message #199130 is a reply to message #198809] Thu, 13 October 2005 20:23 Go to previous messageGo to next message
I created a minimal graphical editor and found the following:
- The 1-pixel gap happens only on the source side of connections, not the
target side.
- The 1-pixel gap happens only if the connection leaves the source node at
an angle between 7.30 and 1.30 on a clock (i.e. only in the "evening").
I can zip and attach the Eclipse project if you want.
news:dijhg9$cgd$1@news.eclipse.org...
>>> target end?
Re: Connections stop one pixel short of node [message #199339 is a reply to message #199130] Fri, 14 October 2005 14:46 Go to previous messageGo to next message
Are you sure that the node to which the connection is attached is entirely
filling its own bounds?
Which connection anchor class are you using?
Here is what I am referring to by a Snippet:
public class ConnectionSnippet {
Display d = new Display();
Shell shell = new Shell(d);
shell.setLayout(new FillLayout());
FigureCanvas canvas = new FigureCanvas(shell);
Figure connectionPanel = new Figure();
RectangleFigure
node1 = new RectangleFigure(),
node2 = new RectangleFigure();
node1.setBackgroundColor(ColorConstants.red);
node1.setOutline(false);
node1.setBounds(new Rectangle(40,40, 50, 30));
node2.setBackgroundColor(ColorConstants.blue);
node2.setOutline(false);
node2.setBounds(new Rectangle(100, 140, 50, 30));
PolylineConnection conn = new PolylineConnection();
conn.setSourceAnchor(new ChopboxAnchor(node1));
conn.setTargetAnchor(new ChopboxAnchor(node2));
connectionPanel.add(node1);
connectionPanel.add(node2);
connectionPanel.add(conn);
canvas.setContents(connectionPanel);
shell.open();
while (!shell.isDisposed())
while (!d.readAndDispatch())
d.sleep();
Re: Connections stop one pixel short of node [message #199371 is a reply to message #199339] Fri, 14 October 2005 15:19 Go to previous messageGo to next message
Well, I hope I didn't make a stupid mistake somewhere, but here is my little
project.
I run it in the debugger as an Eclipse application, all you need is a file
with the extension .diagram to open the editor.
There are 3 hardcoded nodes with connections between them. When the diagram
opens, you should see a gap in the connection between Node3 and Node1 where
it goes into Node3, which is the source. The same is true for the connection
from Node2 to Node3. There is no gap in the connection from Node1 to Node2
because it leaves Node1 at an angle where the gap doesn't occur. When you
move Node2 to the left, the gap in the connection from Node2 to Node3
disappears when the angle becomes 45 degrees or when Node2 is directly
underneath Node1. You have to deselect Node2 to see the effect.
news:diogcm$eqp$1@news.eclipse.org...
> public static void main(String[] args) {
> RectangleFigure
> shell.open();
> d.sleep();
  • Attachment: testGEF.zip
    (Size: 89.55KB, Downloaded 130 times)
Re: Connections stop one pixel short of node [message #200147 is a reply to message #199371] Thu, 20 October 2005 20:39 Go to previous messageGo to next message
Were you able to reproduce the problem with this?
news:dioia2$hhi$1@news.eclipse.org...
> little project.
> diagram opens, you should see a gap in the connection between Node3 and
> Node1 where it goes into Node3, which is the source. The same is true for
> the connection from Node2 to Node3. There is no gap in the connection from
> Node1 to Node2 because it leaves Node1 at an angle where the gap doesn't
> occur. When you move Node2 to the left, the gap in the connection from
> Node2 to Node3 disappears when the angle becomes 45 degrees or when Node2
> is directly underneath Node1. You have to deselect Node2 to see the
> effect.
>> entirely
>> RectangleFigure
>> shell.open();
>> d.sleep();
Re: Connections stop one pixel short of node [message #200449 is a reply to message #200147] Mon, 24 October 2005 14:53 Go to previous messageGo to next message
Please see the snippet I attached and modify it to reproduce the problem you
are having.
news:dj8v9b$til$1@news.eclipse.org...
Re: Connections stop one pixel short of node [message #200472 is a reply to message #200449] Mon, 24 October 2005 16:04 Go to previous messageGo to next message
I cannot see any attachment. If you want, you can send it directly to my
email address.
news:djisgt$j0b$1@news.eclipse.org...
> you are having.
Re: Connections stop one pixel short of node [message #200615 is a reply to message #200472] Tue, 25 October 2005 17:00 Go to previous messageGo to next message
I meant pasted, not attached.
news:djj0mb$poe$1@news.eclipse.org...
>email address.
>> you are having.
Re: Connections stop one pixel short of node [message #201031 is a reply to message #200615] Fri, 28 October 2005 18:01 Go to previous message
Ah, I had overlooked that code. My issue is easy to reproduce making node2
the source of the connection:
conn.setSourceAnchor( new ChopboxAnchor( node2 ) );
conn.setTargetAnchor( new ChopboxAnchor( node1 ) );
news:djlobg$lr2$1@news.eclipse.org...
>>email address.
>>> you are having.
Previous Topic:Copy diagram to system clipboard?
Next Topic:how create new geometrical shapes
Current Time: Tue Dec 10 05:26:42 GMT 2024
Powered by FUDForum. Page generated in 0.08830 seconds
